Home > Technical (L322) > engine wont start |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7833 |
that sounds like the next plan of attack then.........
12th Jan 2013 6:09pm |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 |
hi 47P2 do you think it is the secondary filter then? if so how could i test it, and is it get atable without being on a ramp
Think its just the other side the sill........
12th Jan 2013 6:12pm |
if i do remove the tube to the filter and nothing comes through, how would i know if the problem was the main pump on top of the tank or the secondary one under the car |
12th Jan 2013 6:20pm |
Re the removal of tubes, I'd imagine you'd remove the feed to the secondary pump, and see if fuel is pumped when ignition is on. If so, main pump in tank is going.
12th Jan 2013 6:52pm |
Looking at this forum for the past two years, your most likely candidate is the secondary fuel pump. Luckily it is the easiest to replace and the cheapest of the pumps. Pity you didn't have any previous warning. I hope you get it sorted soon (and the statistics are in your favour of course). MY 2010 5.0 SC Galway green and sand interior!!
12th Jan 2013 6:56pm |
Benfelrr Member Since: 27 May 2012 Location: Wiltshire Posts: 297 |
Really hope this doesnt sound like taking the as it is not! would it not be worth just chucking in some fuel incase? This has happened to a mate before. I am sure it is not but the easiest thing to rule out at least before buying pumps! |
12th Jan 2013 7:19pm |
HI GUYS
12th Jan 2013 9:20pm |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 |
I hope it starts in the morning for you. 2020 Porsche Panamera Turbo Hybrid (V FAST)
12th Jan 2013 9:23pm |
I'm pretty sure the FBH has its own system, if I remember right from a month or so ago when I read about it.
12th Jan 2013 9:26pm |
thanks lads, keeping everything thats long enough crossed , which means just me fingers
12th Jan 2013 9:31pm |
Even if tapping the pump won't help it going, it may still be screwed. I hope it is just the pump as it is probably the easiest apart from no fuel. MY 2010 5.0 SC Galway green and sand interior!!
12th Jan 2013 10:49pm |
unbelievable
13th Jan 2013 1:14pm |
