Home > Technical (L322) > Steering column reach problem |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 |
Well almost got to the bottom of my warning light problem and hey presto the reach on the column goes tits up Its the normal plastic nut that sits on the column has stripped, as you know this is not available and the stealers say you need a whole new column at £1300!! Well f k that im going to make a new one from ally that sits in the column the same as the useless plastic part. I will knock a few up if anyone wants one. One day your life will flash before your eyes......................................make sure yours is worth watching!
11th Jan 2013 9:17pm |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 |
is it the in and out motor nut?? |
11th Jan 2013 9:31pm |
The plastic one that mounts on the column, Ill go get a pic. One day your life will flash before your eyes......................................make sure yours is worth watching!
11th Jan 2013 9:33pm |
This one
11th Jan 2013 9:40pm |
I had exactly the same thing with mine, its a copper like nut, ive got a spare complete steering column in the garage with a spare one in case mine went again
11th Jan 2013 9:55pm |
I'll have a look when we meet up dude and see whats what, just need the thread size to start with, i think its M12X1.75 One day your life will flash before your eyes......................................make sure yours is worth watching!
11th Jan 2013 10:05pm |
ambulancekidd Member Since: 29 Feb 2012 Location: Ayrshire Scotland Posts: 276 |
I'd be very interested in an ally nut to replace the nylon rubbish that Land Robber's use.
11th Jan 2013 10:22pm |
Only a few pence, I may well sell some on E.bay but prob a quid or 2 to cover materials and post to FF members. really to complete the fix apparently you really need to run a corresponding tap down the threaded rod to get rid of the sharp points that develop, I would imagine a tap to be around £10 or borrow mine and post back One day your life will flash before your eyes......................................make sure yours is worth watching!
11th Jan 2013 10:26pm |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 316 |
Had the same problem, constructed me a plastic nut, not easy to change, but it costs me only cents..., the dealer-stealer want to sell a new column...., each nut needs a hour work incl. changing! Regards, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
11th Jan 2013 11:11pm |
Ive read your comments in the thread Uli and ive sent a pm, its a lot easier for me to just get a nut off you as im a bit smashed up from a bike accident and everything takes me 4 x the normal time to do. didnt realise someone else had come up with a solution to the problem already. One day your life will flash before your eyes......................................make sure yours is worth watching!
12th Jan 2013 1:02am |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1698 |
I'd also be interested in buying one of these. My "up and down" is fine but my "in and out" has the same issue.. Ash
12th Jan 2013 8:00am |
I will ask Uli for a price for 2 (or more if anyone else needs one) I'll get em posted to me and post out first class. One day your life will flash before your eyes......................................make sure yours is worth watching!
12th Jan 2013 8:12am |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 |
I woulfnt mind paying for one too please. My colum makes a squealing noise as it retracts. I thought it needed a bit of grease but maybe its starting to strip.
12th Jan 2013 2:42pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
Lot to be said for setting steering wheel to the position you want it in and then turning the function off.
12th Jan 2013 4:01pm |
