Home > Technical (L322) > Steering column reach problem
Page 1 of 4 1234>
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
Well almost got to the bottom of my warning light problem and hey presto the reach on the column goes tits up Censored Its the normal plastic nut that sits on the column has stripped, as you know this is not available and the stealers say you need a whole new column at £1300!! Well f Censored k that im going to make a new one from ally that sits in the column the same as the useless plastic part. I will knock a few up if anyone wants one. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #163870 11th Jan 2013 9:17pm
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
is it the in and out motor nut??
Post #163873 11th Jan 2013 9:31pm
JohnnyDangerous
The plastic one that mounts on the column, Ill go get a pic. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #163875 11th Jan 2013 9:33pm
I'm sure if read a few posts about this in the last year. That would be good if you could manufacture a fix. Thumbs Up Previously..
Post #163878 11th Jan 2013 9:36pm
JohnnyDangerous
This one
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #163883 11th Jan 2013 9:40pm
cliffy
I had exactly the same thing with mine, its a copper like nut, ive got a spare complete steering column in the garage with a spare one in case mine went again
All i did was take it out and the thead bar i then hit each side with a hammer until it slimmed down then re threaded it with the bar
Post #163890 11th Jan 2013 9:55pm
JohnnyDangerous
I'll have a look when we meet up dude and see whats what, just need the thread size to start with, i think its M12X1.75 One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #163894 11th Jan 2013 10:05pm
ambulancekidd
Scotland 2005 Range Rover Vogue Td6 Oslo Blue
I'd be very interested in an ally nut to replace the nylon rubbish that Land Robber's use.
How much would they cost? Bow down
Robert The reason women's minds are cleaner than a mans mind is that women change their minds more often!
When women say fine a mans in deep doodoo as fine has so many meanings.
Post #163895 11th Jan 2013 10:22pm
JohnnyDangerous
Only a few pence, I may well sell some on E.bay but prob a quid or 2 to cover materials and post to FF members. really to complete the fix apparently you really need to run a corresponding tap down the threaded rod to get rid of the sharp points that develop, I would imagine a tap to be around £10 or borrow mine and post back One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #163896 11th Jan 2013 10:26pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Had the same problem, constructed me a plastic nut, not easy to change, but it costs me only cents..., the dealer-stealer want to sell a new column...., each nut needs a hour work incl. changing! Regards, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #163904 11th Jan 2013 11:11pm
JohnnyDangerous
Ive read your comments in the thread Uli and ive sent a pm, its a lot easier for me to just get a nut off you as im a bit smashed up from a bike accident and everything takes me 4 x the normal time to do. didnt realise someone else had come up with a solution to the problem already. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #163918 12th Jan 2013 1:02am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
I'd also be interested in buying one of these. My "up and down" is fine but my "in and out" has the same issue.. Laughing Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #163930 12th Jan 2013 8:00am
JohnnyDangerous
I will ask Uli for a price for 2 (or more if anyone else needs one) I'll get em posted to me and post out first class. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #163931 12th Jan 2013 8:12am
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
I woulfnt mind paying for one too please. My colum makes a squealing noise as it retracts. I thought it needed a bit of grease but maybe its starting to strip.
Many thanks Thumbs Up MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #163996 12th Jan 2013 2:42pm
Lot to be said for setting steering wheel to the position you want it in and then turning the function off.
Steering wheel stays where it is and nothing wears out or breaks. Thumbs Up
Post #164021 12th Jan 2013 4:01pm
Page 1 of 4 1234>
