Home > Maintenance & Mods (L322) > Battery TDV8 |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3838 |
I bought a new Bosch battery and with a bit of patience and the bonnet in access mode I got it to fit without any modifications. However although it lasts longer than the battery I took out it still goes flat after a couple of days parked ( like this morning ) I am a bit uncertain what to do next as I have in the past left it parked for a couple of weeks, admittedly in warmer weather, and it would start no problem. So I might have wasted the money buying the Bosch as clearly there is an underlying problem. At least I can investigate now as its stopped raining Geoff |
5th Jan 2013 11:30am |
awclymm Member Since: 09 Jun 2012 Location: Cheshire, UK Posts: 135 |
Thanks all for the advice / encouragement from recent contributors.
6th Jan 2013 12:57pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6737 |
Well done that man! Got - 2017 SDV8 Autobiography in Loire Blue
6th Jan 2013 1:43pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7958 |
Well done that man |
6th Jan 2013 1:49pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35419 |
all good and well hacking the plastic but i wonder how you would fair taking the battery back if it starting failing... ... - .- -.
7th Jan 2013 9:09am |
EDWARD757 Member Since: 10 May 2007 Location: SOUTH COAST Posts: 181 |
Just ordered another battery using the UKPAS25 code..also ordered from ECP via quidco for a little extra cashback!
7th Jan 2013 9:48am |
my bosch 020 had trouble starting the range so as it was only a year old i took it back to ECP and they replaced it without testing it... ... - .- -.
7th Jan 2013 9:50am |
I don't think I would fare very well at all - but for £100 that's a risk I am prepared to take for the benefit of having a car in which I can use the FBH with impunity without worrying about subsequently starting the engine! |
8th Jan 2013 12:02pm |
Can't disagree with that! Got - 2017 SDV8 Autobiography in Loire Blue
8th Jan 2013 12:28pm |
My battery arrived today - Bosch 110 A/H 920CCA - Euro car parts £133 >>>£99 with UKPAS25 code then £4.99 cashback from quidco. Followed the battery disconnection guide allowing plenty of time for car to sleep. Bonnet into access, which was straight forward. 2 year old Bosch 100A/H out (back to costco at earliest opportunity!) and the new 110A/H went in pretty easily with no hacking...wheres the snag?
9th Jan 2013 8:34pm |
good job Ed... ... - .- -.
9th Jan 2013 9:07pm |
alx Member Since: 13 Jul 2014 Location: Beds Posts: 99 |
Just to share my experience on the battery for the TDV8. I've searched ebay and Varta 610 402 092 came up as a compatible battery for the car. Ordered it direct from the seller's website (was a little cheaper that way ) and got it delivered shortly after. Today set to change out the battery just to find out the Varta is longer by about 40mm. Measured the battery tray and it looked like a snug fit so I gave it a try. It did fit but the positive terminal which is the size of small pack of cigarettes wouldn't go. Lifted one end of the battery, bolted the terminal then lowered it down. It sits fine but no room to either side now. In case I need to remove a positive I will need to lift the battery again. Not the end of the world but a little annoying given that it came from a big reseller and was advertised as a replacement for the OEM battery on a TDV8. Other than that, happy days! |
4th Sep 2015 3:26pm |
the positive terminals are indeed hard to get to and its easier to disconnect the negative .. ... - .- -.
4th Sep 2015 5:04pm |
TDV8John Member Since: 08 Nov 2015 Location: Kent Posts: 19 |
Whilst at the risk of resurrecting an old post just thought I would share my confirmation that with a bit of elbow grease, cursing, brute force and some trimming of the moulding at each end of the battery you can indeed shoe horn the the 393mm long battery into the space available.
11th Mar 2016 6:02pm |
