![]() | Home > Maintenance & Mods (L322) > Battery TDV8 |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3887 ![]() ![]() ![]() |
I bought a new Bosch battery and with a bit of patience and the bonnet in access mode I got it to fit without any modifications. However although it lasts longer than the battery I took out it still goes flat after a couple of days parked ( like this morning |
awclymm Member Since: 09 Jun 2012 Location: Cheshire, UK Posts: 135 ![]() ![]() ![]() |
Thanks all for the advice / encouragement from recent contributors.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6760 ![]() ![]() ![]() |
Well done that man! |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7998 ![]() ![]() ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35600 ![]() ![]() |
all good and well hacking the plastic but i wonder how you would fair taking the battery back if it starting failing... ... - .- -.
EDWARD757 Member Since: 10 May 2007 Location: SOUTH COAST Posts: 181 ![]() ![]() |
Just ordered another battery using the UKPAS25 code..also ordered from ECP via quidco for a little extra cashback!
my bosch 020 had trouble starting the range so as it was only a year old i took it back to ECP and they replaced it without testing it... ... - .- -.
I don't think I would fare very well at all - but for £100 that's a risk I am prepared to take for the benefit of having a car in which I can use the FBH with impunity without worrying about subsequently starting the engine! |
Can't disagree with that! |
My battery arrived today - Bosch 110 A/H 920CCA - Euro car parts £133 >>>£99 with UKPAS25 code then £4.99 cashback from quidco. Followed the battery disconnection guide allowing plenty of time for car to sleep. Bonnet into access, which was straight forward. 2 year old Bosch 100A/H out (back to costco at earliest opportunity!) and the new 110A/H went in pretty easily with no hacking...wheres the snag?
good job Ed... |
alx Member Since: 13 Jul 2014 Location: Beds Posts: 99 ![]() ![]() ![]() |
Just to share my experience on the battery for the TDV8. I've searched ebay and Varta 610 402 092 came up as a compatible battery for the car. Ordered it direct from the seller's website (was a little cheaper that way |
the positive terminals are indeed hard to get to and its easier to disconnect the negative .. ... - .- -.
TDV8John Member Since: 08 Nov 2015 Location: Kent Posts: 19 ![]() ![]() ![]() |
Whilst at the risk of resurrecting an old post just thought I would share my confirmation that with a bit of elbow grease, cursing, brute force and some trimming of the moulding at each end of the battery you can indeed shoe horn the the 393mm long battery into the space available.
