![]() | Home > Maintenance & Mods (L322) > NSF Air Bag Leaking |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7911 ![]() ![]() ![]() |
I hope the car hasn't started 2013 as it wishes to proceed, but this morning it was down on NSF after being left in off road height.
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1754 ![]() ![]() ![]() |
From what I remember having had this before on my P38 it depends on why it went in the first place. If it got a tear from something then no need to do the others. If it went because it's worn (you can usually tell by crease lines and drying out of rubber bags) then chances are another may well be on it's way out.
Thats pretty much my thinking if I'm honest.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Best to do both, it's always advised to replace shocks and/or springs in pairs, in this case they are combined! Depends if you know the history of the existing units? I am guessing that they are the originals, in which case they have reached EOL |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
The rears rarely go wrong Joe90, probably because they are cheap |
You have a PM sir ![]() |
oliver9627 Member Since: 25 Oct 2012 Location: Chipping Norton Posts: 51 ![]() ![]() ![]() |
I had my front passenger side airbag leaking a while back. I found some new struts on the bay for about £230. I was to tight to replace both. If i had the spare cash i would have done but i knew i had to spend it on other bits. (tyres). From what i can see and feel when driving the car is fine. I changed it with a friend and it took about twenty mins. Gone:
20 minutes to completely change an airbag front strut !! Star performance !! .
If you can hear and feel air - there is no more waiting to do. You only have another couple of hours of driving left - at best. Time to replace.
Thanks gents.
Bear in mind that removing any suspension parts, especially front struts, will require geometry setting up and if this is done properly it means putting the suspension into tight tolerance mode and doing 4 wheel tracking. That's not exactly a 2 minute job in itself. |
Mmmm. Good point.......... 2011 Range Rover Vogue SE 4.4 TDV8
Bob the B Member Since: 10 Jun 2011 Location: Newcastle upon Tyne Posts: 163 ![]() ![]() ![]() |
I changed my front air bags at the beginning of the summer last year. Bought the Dunlop ones and have no problems with them so far.
You couldn't write it............. |
