![]() | Home > Maintenance & Mods (L322) > NSF Air Bag Leaking |
Don't wanna say I told you so, but.... |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7910 ![]() ![]() ![]() |
Cheers Steve.
Car been in the garage today, 2 new struts fitted. £132 all in. (I supplied the parts)
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35649 ![]() ![]() |
not a bad price that...have fun with the IIDTool.. ... - .- -.
Apparently during transit from Dan, someone had dropped one of the strut boxes on its end, which broke the bit that holds the 3 bolts "captive" where it comes through the wing in the engine bay, so the garage had to tack weld them to stop them spinning to fasten the nuts on, so not a bad price all in all.
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 ![]() ![]() ![]() |
Those top bolts are only supposed to be tightened to 40 odd ft /lbs. Sounds like the garage snapped one of them off throught over tightening. Just done mine y/d and if your packaging was anything like mine, there is no chance they could drop the box and break one off. Atleast they sorted it though . MY2010 TDV8 Vogue Ipanema Sand
Fitted two to mine last week. Seem fine fit perfect MY2010 TDV8 Vogue Ipanema Sand
T111RDY Member Since: 21 May 2012 Location: Dunbar Posts: 187 ![]() ![]() ![]() |
Cheers! |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Yes we have fitted them recently without any issue |
Did those of you that have replaced these recently have to replace the bolts also?
No but they are often seized into the hub assy and can be a real b |
Ok - thanks! l:OolΞΞΞΞΞΞloO:l
Parts have arrived - ready for fitting on Saturday! (Weather permitting |
