Home > Maintenance & Mods (L322) > NSF Air Bag Leaking
mjdronfield
NSF Air Bag Leaking
I hope the car hasn't started 2013 as it wishes to proceed, but this morning it was down on NSF after being left in off road height.
I started the car up and could hear a loud hiss, and then I could feel the hole and air coming out.
Doesn't seem too bad at normal height, if not OK..........
I've done a search on here and see that Island 4x4 are likely to be cheapest for the Delphi units, but do you have to replace both front ones ?
I've a feeling I know the answer to this if I'm honest. I always tend to do 2 springs or shocks on a car.........but it doubles the cost of repair, which ain't cheap.
Is it best to wait till it totally goes, ? Suppose that will put strain on the compressor...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #160956 1st Jan 2013 12:45pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
From what I remember having had this before on my P38 it depends on why it went in the first place. If it got a tear from something then no need to do the others. If it went because it's worn (you can usually tell by crease lines and drying out of rubber bags) then chances are another may well be on it's way out.
Regarding leaving it till it does go completely - up to you but you run the risk of it going when it's totally inconvenient and you are left either high and dry or a rather uncomfortable drive home/to garage. Would personally want to have wife and kids in the car on a long journey faced with that. (just a personal opinion though) Ash
2016 SDV8 AB
Post #160961 1st Jan 2013 1:17pm
mjdronfield
Thats pretty much my thinking if I'm honest.
Just trying not to spend money unnecessarily.
Just been out and it looks like the entire front has now dropped, so assume its "normal" for the drivers side to drop, as the air will have escaped out the passenger side air bag. (depending on what the cross link valve is doing.
Its going to the bodyshop in the morning for a bit of work, so will have to wait till thats done.......
Cheers 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #160971 1st Jan 2013 2:57pm
TugRR
Seem to remember Gordon Lamb in Chesterfield selling airbags for FF not long ago via their ebay shop - might be worth a call ?
Thumbs Up Where do you go after one of these . . . ?
Post #160998 1st Jan 2013 5:49pm
Best to do both, it's always advised to replace shocks and/or springs in pairs, in this case they are combined! Depends if you know the history of the existing units? I am guessing that they are the originals, in which case they have reached EOL Big Cry
Having replaced my fronts a year ago, am still waiting for the rears to give out Whistle .
Post #160999 1st Jan 2013 5:55pm
The rears rarely go wrong Joe90, probably because they are cheap Laughing
Craig
Post #161000 1st Jan 2013 6:22pm
Re: NSF Air Bag Leaking
You have a PM sir Thumbs Up
Post #161019 1st Jan 2013 7:41pm
oliver9627
United Kingdom 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
I had my front passenger side airbag leaking a while back. I found some new struts on the bay for about £230. I was to tight to replace both. If i had the spare cash i would have done but i knew i had to spend it on other bits. (tyres). From what i can see and feel when driving the car is fine. I changed it with a friend and it took about twenty mins. Gone:
Golf GT TDI 150- Still got.
BMW 325TD
Range Rover Classic
Defender 90
Post #161144 2nd Jan 2013 7:35am
20 minutes to completely change an airbag front strut !! Star performance !! .
Post #161156 2nd Jan 2013 9:13am
SteveMFr
Site Sponsor
If you can hear and feel air - there is no more waiting to do. You only have another couple of hours of driving left - at best. Time to replace.
New struts no longer require a second mortgage. http://www.island-4x4.co.uk/suspension-par..._2839.html
Delphi Air Spring Front LH Range Rover L322 (02-06) Delphi OE RNB000750 RNB000750G
£219.99 (excl. VAT)
or
Part Number : RNB000750
Web Exclusive Price
Dunlop Air Spring Front LH Range Rover L322 (02-06) Dunlop RNB000750
£185.00 (excl. VAT)
Delphi is the OEM supplier. TBH, I would prob trust Dunlop too, tho. Do both and be happy. Razz
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #161158 2nd Jan 2013 9:19am
mjdronfield
Thanks gents.
A friendly chap on here, going by the name of Dan, was able to match the price above for the new Delphi units, so 2 new ones have been ordered.
Just need to sort fitting now.
Car still in bodyshop.......
My local specialist recons £270 + VAT to fit them both.
They are turning into dreamers. Am shopping around now.......
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #161663 3rd Jan 2013 6:36pm
mzplcg
Bear in mind that removing any suspension parts, especially front struts, will require geometry setting up and if this is done properly it means putting the suspension into tight tolerance mode and doing 4 wheel tracking. That's not exactly a 2 minute job in itself.
Post #161673 3rd Jan 2013 7:09pm
mjdronfield
Mmmm. Good point.......... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #161675 3rd Jan 2013 7:12pm
Bob the B
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
I changed my front air bags at the beginning of the summer last year. Bought the Dunlop ones and have no problems with them so far.
There is a good write up on how to do them somewhere that I used and it was easy enought (2 -3 hours max).
Hardest part was trying to line the 3 bolts with the 3 holes and put the nuts back on, but I was trying to do this myself Shocked
Post #161991 5th Jan 2013 9:13am
mjdronfield
You couldn't write it............. Rolling with laughter
Just picked car up from bodyshop, they've done a good job, but the car now has "Air Susp Inactive" on the dash and its down on the bump stops front passenger side.
Not totally surprised, but I've just sold my RSW All Comms and posted the lead off yesterday and I start a new job Monday, so am a bit stuck.
Excellent timing me thinks !!
Upshot - I'll have to use it for the 4 mile trip to work for 2 days and its booked in to get the 2 new struts fitted Wednesday...........
Don't see any way around it.
Whistle 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #162010 5th Jan 2013 11:38am
