Home > In Car Electronics (L322) > lost cd, radio, gps screen, voice control etc |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 |
HI ARENAITCH
5th Dec 2012 7:37pm |
hi Guys, just thought i would update you all on what is happening regarding my faults. today i was planning to start the process of elimination ( ), hopefully in solving the current issues with the RR.
8th Dec 2012 9:32pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
I'm wondering if it has dried out?? Is the nokia working now. Can you see the car with your mobile phone? Is it connecting? Have you taken the connector off the Nokia (not the fibre optics) to check for water damage, ie white powder/gunge on the pins? Previously..
8th Dec 2012 9:55pm |
HI CONTRABAND, no the nokia is still the only part that is not working? i say not workingn but i dont know if it is or it isent . all i know is that when i press the phone hard key, the screen displays ( no phone fitted )?
8th Dec 2012 10:03pm |
It does sound like the Nokia has packed up... But before you do anything else... Take the connections to the Nokia off and check them. It might be they just need a good clean if they have water damage. It is a 2 minute job, no tool required, to check. Previously..
8th Dec 2012 10:10pm |
hi mate, ok i will check that in the morning. i will be wondering all night if its all going to come on again in the morning |
8th Dec 2012 10:17pm |
hi contraband,, ok this is the latest situation. i have been a bit busy today but just been out to the car to check if everything is still running, which it was,! audio and gps. so i decided to do as you suggested and check the main plug on the nokia to see if there was any signs of water damage etc as i still could not connect my phone.
9th Dec 2012 5:29pm |
This is actually all good news... Get yourself an electrical cleaner spray, one that leaves no residue. Disconnect the plug. Take the keys out of the ignition and wait 15 mins to make sure everything is asleep, so to speak. Or if happier, disconnect battery. Spray the connector and blast the crap out of it. Let it dry completely. You could do the same with he Nokia but I think it is probably had it, but it's worth a try. I had exactly the same fault and had to buy a new Nokia, well, eBay.
9th Dec 2012 5:45pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
A needle with the end broken off acts as a good scraper for the small holes in the plugs in conjunction with contact cleaner as above.
9th Dec 2012 5:57pm |
hi mate thanks again for your constant very swift replies to my messages etc. it is very refreshing to find a forum where everyone is actually happy and prepared to offer help and advice.
9th Dec 2012 6:07pm |
Wd40 is an oil!! Do not use that.. Computer shop, yes, they may have some. Can you buy online and get delivery where you are? When I opened up my Nokia it was soaking wet. I dried it out, but it was dead. I bought one for £40 from another member. you have nothing to lose by trying to dry yours, but you must make sure the connector and pins are clean. Previously..
9th Dec 2012 6:16pm |
bizzybus Member Since: 19 Aug 2012 Location: merseyside Posts: 53 |
Bob The fourth screw on the nokia is under the security seal middle of circle. usually no one will fix if seal broken, but wiggs does not fix our type anyways. (SEE WHAT HAPPENS WITH HEATED SEATS) |
9th Dec 2012 6:41pm |
wiggs Member Since: 29 May 2010 Location: Manchester Posts: 182 |
I did tell you to check this on the first page of the post Bluetooth Exchange www.bluetoothexchange.co.uk |
9th Dec 2012 6:51pm |
hi guys thanks for that. i have the back off now and actually apart from a little condensation for want of another word, on the top of the stainless protection cover, there was no water inside other than the above. looking at the circuit board, it all seems clean enough but there was a bit of staining around the top left; top right and lower right. it came straight off with a cotton bud but i i will try to clean it a bit with the contact cleaner? you never know it might still work but it does not sound too hopefull.
9th Dec 2012 6:53pm |
