![]() | Home > Technical (L322) > Trans Failsafe Prog message on dash |
Could be overheating tranny due to blocked bottom section of radiator stopping trans oil cooler from working efficiently under load. Get the Cooling system PRESSURE flushed before you damage the box and/or oil. |
mick79 Member Since: 24 Nov 2012 Location: Hampshire Posts: 42 ![]() ![]() |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
Sorry if I've mentioned this before, but gyrogypsy over on rangerovers.net is having spare potentiometers manufactured so that the whole transfer box shift motor doesn't need replacing in the event of a potentiometer fault.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
i would say electrical gremlin ..same thing happens with the touch screen going blank if you start and quickly take out the key..
Harris Member Since: 02 Apr 2013 Location: Northants Posts: 155 ![]() ![]() ![]() |
Thanks hope that is all it is |
Further errors today, put a new post up to describe |
TtheArab Member Since: 26 Apr 2013 Location: Dunblane, Scotland Posts: 89 ![]() ![]() |
FWIW I started out with constant TFP errors. Diff went and during replacement gearbox oil was replaced followed by new battery when errors were still happening. Errors are now less frequent but occasional. Usual procedure is cycle ignition around a dozen time and it clears.
