Home > Technical (L322) > Trans Failsafe Prog message on dash
Page 3 of 4 <1234>
RRPhil
Just for the avoidance of doubt, the shift motor :
Can be unbolted & removed from the transfer box in situ. There’s no requirement to remove the transfer box from the vehicle.
Phil
Post #77647 25th Aug 2011 10:52pm
Day 3 Got it back from stealers
They fixed the stiff gear shift and PARK problem, and I got no faults on the 20 mile drive home (though I didn't push it as wife was following me - no sense of direction)
I'll do the resistance check on the motor tomorrow. .
Post #77733 26th Aug 2011 5:05pm
J.Seven
Portugal 2003 Range Rover Vogue Td6 Monte Carlo Blue
wedgel322 wrote:
cheers mikeyjd, any help is much apprieciated. Hopefully the garage will take info like this on board???
I will let the forum know what they say tomarrow. In the meantime, any more ideas would be good for me to take to garage in morning.
Any update? J.Seven
Post #78192 30th Aug 2011 12:53am
wedgel322
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
just to keep you all updated
Got my rangie back and done 500 trouble free miles now ! It was the torque converter and the garage put a recon box with all recon parts in for £1320 inc vat. 12 months or 12000 miles warrenty.
The service from the garage was very good! Called GearTrain in Bradford and they do loads of rangies every week for gearbox problems, Pile of torque converters in corner of yard ! Im in the AA and have the breakdown repair cover for £25 a month so they paid first £475 after taking a £25 excess.
Thanks for your advice everyone and i hope this helps others. 2003 Range Rover HSE 3.0 TD6
Java Black, Cream Leather Heated seats all round, Sat Nav, Rear TV's.
2013 Range Rover Autobiography 4.4 SDV8
Black, black and piano black. Rear entertainment system. 22 inch turbines
Post #79216 4th Sep 2011 7:38pm
Well after spending a week or two playing around with a secondhand shift motor and my existing one, all resulting in the TFP message and stuck in Low Range. I gave up all hope and bought a new motor from LRDirect. (This is what the stealer said was wrong). Nope, still getting the TFP message. I am now close to suicide Big Cry Big Cry .
Post #79887 8th Sep 2011 3:46pm
Windscreen Dave
United Kingdom 2003 Range Rover Vogue Td6 Alveston Red
Joe was there any further development on this as I have exactly the same fault codes have a new transfer motor arriving tomorrow which from what most people have said this is what it points to. Now slightly worried as your post said this did not work Sad
Post #131686 17th Jul 2012 9:15pm
wedgel322
@ windscreen dave
I am 10000 miles & 11 months into my recon box and new torque converter and everything is ok. I have read a few posts on here that would suggest it may be the torque converter if your getting the TFP message on the dash just like it was for me.
If you get the engine and box warm and the message comes on and you do some reverse and drive changes on a little slope it will struggle to hold the car in drive or reverse after a while if its the torque converter as it will just slip and that may help you pinpoint the problem? 2003 Range Rover HSE 3.0 TD6
Post #131690 17th Jul 2012 9:55pm
Windscreen Dave
Car drives absolutely fine with no difference in gear change or performance which is what led me to believe it is transfer motor but when I saw joe90 post about the various faults including short to earth mine is displaying all of those fault codes on the reader for transfer box but after he said that it didn't alter TFS when replacing motor it has slightly worried me.
Post #131692 17th Jul 2012 10:04pm
KARMANN
2002 Range Rover Vogue 4.4 V8 Java Black
I had a similar issue with mine-reving very high andf hardly moving then all of a sudden a huge thump and the car would spring into gear and drive as normal. sometimes it would just go straight to trans failsafe message. I had a oil leak from the bottom of my gearbox-took it to the garage they drained it fixed the leak and refilled-that was a year and a half ago and its been fine since.
Fraser
Post #131699 17th Jul 2012 10:59pm
Windscreen Dave
Replaced the transfer motor on Wednesday had all codes reset and everything is working fine. Best of all no annoying pinging telling me that either my transfer box is in neutral or the trans fail safe prog. Bliss.
Post #132236 20th Jul 2012 6:07pm
Sorry I missed this thread coming back to life!
My issue, which I haven't tackled since the autumn seems to lie within the system somewhere. I can go into low range, but can't get back into high range, even with a new shift motor on board. I have to fit an old shift motor and manually wind it back into high range.
I may have to bypass the ecu controller and fit a switch to wind it back.......
But as Windscreen Dave has found, it could just be a knackered shift motor.
Still got a brand new shift motor sitting in the garage! .
Post #132237 20th Jul 2012 6:13pm
Windscreen Dave
Joe not trying to teach you to suck eggs but did you make sure that you wound the cog on the transfer box all the way clockwise and then turn the notch on motor so it lines up before reconnecting it. (just a thought). Regards Dave.
Post #132239 20th Jul 2012 6:28pm
Thanks Dave Smile
Yes I have got quite good at it now having had the motors on and off about 20 times Smile .
Post #132266 20th Jul 2012 10:38pm
gridlocked
2006 Range Rover Vogue Td6 Santorini Black
trans fail pro
had my 06 rangie 6 month's now and have this same fault several times.i bought the car from stratstones with a 6month warrenty.i keep taking it back they reset the fault but can't find anything wrong.the trans failure pro come's on when i'm going up hill.has anyone got any idea's. love it
Post #147433 22nd Oct 2012 8:48am
mick79
2004 Range Rover Vogue 4.4 V8 Java Black
Had this message pop up on saturday into a 20min drive, no differance in drive just the damn bleeping noise carried on to my destination parked car up for 1 hour. Came back drove home 20mins no fault since.
Cheers Mick Owner of a bottomless pit, Sorry i mean range rover l322.
Post #153678 26th Nov 2012 8:10pm
Page 3 of 4 <1234>
