Home > Maintenance & Mods (L322) > Brakes! |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless Iām not at home, in which case Iām somewhere else. Posts: 6740 |
Do you mean just pads or pads and disks? Got - 2017 SDV8 Autobiography in Loire Blue
20th Nov 2012 5:46pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Personally think with a reasonably low ability brakes are more than possible! If you have a reasonable socket set, Allen keys, hammer, you should be more than capable. Think there are set of discs and pads on eBay! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
20th Nov 2012 5:52pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Got mine from duckworth parts - very reasonable. Suggest sending a pm to Dan.
20th Nov 2012 7:11pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3756 |
Depends where you buy. Main agent quoted me £450.00 , but it can be done for £70ish DIY |
20th Nov 2012 10:14pm |
here you go :-
20th Nov 2012 10:15pm |
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 |
Recently replaced all four sets on my L322 V8 - simple enough job as long as you have the ability to jack the car up and support it securely. The only tough bit was 'encouraging' the calliper bolts to release. Plenty of copper ease on the back of the pads and its a simple replacement job as long as you are confident and know what you are doing. There are plenty of youtube videos (Storey I think) on ow to do this.
21st Nov 2012 9:11am |
£150+ at an Indy |
21st Nov 2012 9:21am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
This is a good read if you want to change you own discs / pads.
21st Nov 2012 10:09am |
ricknayton Member Since: 07 Apr 2012 Location: Essex Posts: 29 |
Thanks a lot for all your help guys. Much appreicated.
21st Nov 2012 12:59pm |
yes, on one of the RR's and they are fine, absolutely no issues, plus saved £350ish on the stealer. I am given to understand that Mintex are OEM, but don't really care, Mintex are good anyway. |
21st Nov 2012 8:57pm |
Thanks a lot for your help Vogue. Really appreciate it.
22nd Nov 2012 10:35am |
noddy5vogue Member Since: 21 Jan 2011 Location: Blackpool Posts: 38 |
just ordered new for mine all round and handbrake shoes from euro car parts 30% off at moment and 25000 mile warrenty |
22nd Nov 2012 6:23pm |
DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379 |
Gaz, is that Labour only? I've just been quoted £560 +VAT for supply and fit of front and rear brakes, discs and sensors. Also, any experience with Pagit Pads/Discs? African Bush Junkie ... in London! Stats: 2006 TD6 Vogue SE 1972-2015 DeRanged Rover 2001 P38 dHSE (SOLD) |
10th Jan 2013 3:03pm |
Durham4416 Member Since: 10 Dec 2012 Location: Middlesbrough Posts: 248 |
Pagid are oem fit for a lot of top end manufacturers so you won't go wrong with them |
10th Jan 2013 3:11pm |
