Home > Maintenance & Mods (L322) > Brakes!
ricknayton
United Kingdom 2006 Range Rover Vogue SE Td6 Santorini Black
Brakes!
Hi guys,
Does anyone know what sort of price i should be paying for new front brakes to be fitted on my 2006 Vogue?
Even better, if i can purchase them and fit myself!
Any help would be much appreciated. This is all new stuff to me.
Thanks.
Rick
Post #152338 20th Nov 2012 5:28pm
Location: my House, unless Iā€™m not at home, in which case Iā€™m somewhere else.
Do you mean just pads or pads and disks? Got - 2017 SDV8 Autobiography in Loire Blue
Post #152339 20th Nov 2012 5:46pm
Personally think with a reasonably low ability brakes are more than possible! If you have a reasonable socket set, Allen keys, hammer, you should be more than capable. Think there are set of discs and pads on eBay! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #152341 20th Nov 2012 5:52pm
Got mine from duckworth parts - very reasonable. Suggest sending a pm to Dan.
Didn't fit them myself after reading how they can be a pain in the ar$e to get off and I wanted my brake fluid changing. Otherwise seems an easy job.
Post #152352 20th Nov 2012 7:11pm
Vogue
Depends where you buy. Main agent quoted me £450.00 , but it can be done for £70ish DIY
Post #152418 20th Nov 2012 10:14pm
Vogue
here you go :-
http://www.ebay.co.uk/itm/130723233589?ssP...1439.l2649
Post #152419 20th Nov 2012 10:15pm
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Recently replaced all four sets on my L322 V8 - simple enough job as long as you have the ability to jack the car up and support it securely. The only tough bit was 'encouraging' the calliper bolts to release. Plenty of copper ease on the back of the pads and its a simple replacement job as long as you are confident and know what you are doing. There are plenty of youtube videos (Storey I think) on ow to do this.
Got all my pads / sensors from Dan on this forum - prompt service as always and a good price. "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ā€”ā€”ā€” Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #152473 21st Nov 2012 9:11am
£150+ at an Indy
Post #152478 21st Nov 2012 9:21am
This is a good read if you want to change you own discs / pads.
It's specifically for a D3 but the principles are the same for a FFRR.
Bodsy's Brake Bible
Post #152493 21st Nov 2012 10:09am
ricknayton
Thanks a lot for all your help guys. Much appreicated.
Vogue, have you used these before? http://www.ebay.co.uk/itm/130723233589?ssP...1439.l2649
Post #152546 21st Nov 2012 12:59pm
Vogue
yes, on one of the RR's and they are fine, absolutely no issues, plus saved £350ish on the stealer. I am given to understand that Mintex are OEM, but don't really care, Mintex are good anyway.
Post #152623 21st Nov 2012 8:57pm
ricknayton
Thanks a lot for your help Vogue. Really appreciate it.
Just got to fit them now! Rolling with laughter
Post #152716 22nd Nov 2012 10:35am
noddy5vogue
United Kingdom 2003 Range Rover Vogue Td6 Java Black
just ordered new for mine all round and handbrake shoes from euro car parts 30% off at moment and 25000 mile warrenty
Post #152777 22nd Nov 2012 6:23pm
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
Gazellio @ Prestige Cars wrote:
£150+ at an Indy
Gaz, is that Labour only? I've just been quoted £560 +VAT for supply and fit of front and rear brakes, discs and sensors.
Also, any experience with Pagit Pads/Discs? African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #163360 10th Jan 2013 3:03pm
Durham4416
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
Pagid are oem fit for a lot of top end manufacturers so you won't go wrong with them
Post #163365 10th Jan 2013 3:11pm
