Home > Maintenance & Mods (L322) > Lubeguard & Dr Tranny
Have any of you high mileage guys heard of or used this stuff. They are highly recommending Dr Tranny as quick and effective fix for Torque Converter Judder and Lubeguard appears to be a good way of reducing transmission fluid temperate and with overheating being the arch enemy....
http://www.lubegard.com/~/C-230/Dr.+Tranny+Instant+Shudder+Fixx
http://www.lubegard.com/~/C-112/LUBEGARD+A...Protectant
Just interested if any of these products actually work?
Post #151257 14th Nov 2012 5:38pm
piecost76
With both "Lube" & "Tranny" in the titles, am I the only one who thought this subject amusing?
I'll get me coat Embarassed Quis custodiet ipsos custodes?
15 MY 110 XS USW
54 FFRR Vogue TD6 Touchscreen - Gone!
56 FFRR TDV8 VSE - Gone!
Post #151261 14th Nov 2012 6:27pm
No you are not piecost Laughing
Who is doing the recommending Gary ? .
Post #151263 14th Nov 2012 6:40pm
They look and seem very good. I remember seeing something similar at the motor show a few years back, and it was a single shot type thing. On the surface it seemed very very good. The problem here is out gearbox's and TC are expensive and it's a big risk to use one of these types of products. RRPhil might have some input or know about these things. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #151276 14th Nov 2012 8:08pm
Its a thread on the DISCO3 site they say Dr Tranny has cured a number of TQ judders completely.
I was more interested in the heat reducing properties of the LUBEGUARD as a very high percentage of the BMW RR <2005MY Gearbox failures are linked to Gearbox Overheating linked to blocked/clogged lower radiators and Oil Coolers/pipes.
A product that significantly reduces the gearbox operating temperature without doing anything else must be a good idea if it has been properly developed to work with the latest synthetic transmission oils - which it looks like is has..... (It appears to also protect the clutch plates in the Torque Converter by coating them-it contains ethers that removes the glaze on the internal clutches )
http://www.disco3.co.uk/forum/topic85972.html
Post #151292 14th Nov 2012 10:34pm
hongkongphooey
Isle Of Man
Sounds like a porn version of Dempsey and Makepiece. Whistle
Sorry for the Hijack. Thumbs Up
Post #151293 14th Nov 2012 10:37pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
I had something described as "redlube" additive put in when I had a gearbox flush and filter change. Seems to have done a god job so far.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #151298 14th Nov 2012 11:12pm
lex99
would love rrphil's thoughts on this.
Post #212581 26th Sep 2013 10:29pm
Gary, use this all the time pal on slipping 6 speed boxes Thumbs Up Goes in all of my own cars every time i service the box... Funnily enough, i put two in the TDV8 gearbox today while i changed the fluid... No issues with the box but it does seem to make them smoother too...
My TDV6 Disco was playing up something terrible and one of these shudder fix tubes solved the problem instantly 18 months ago Thumbs Up
Post #212582 26th Sep 2013 10:55pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
My gearbox has the odd shudder and sometimes feels like it is "slipping" if I accelerate hard from a lowish speed (i.e. roll up to a junction then give some gas). Are these products likely to improve the problem and if so how easy it to get to the fill point (i.e. can I just raise the suspension put some wooden blocks under the frame for security or do I need to put on a ramp etc... to access) I only have the factory jack which I know is not great and a 2.5T bottle jack that Im not sure I would trust on the FF.
Is there a way to check the gear box temp either using the onboard functions or my IID Tool.
Comments welcome There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #297219 5th Dec 2014 5:02pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
A garage tried the shudder gear in my TD6 a few years ago, it didn't make any difference.
They ended up changing the TC.
Post #297221 5th Dec 2014 5:20pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
I suppose once a gearbox starts with the shudder symptoms, spending around £20 is worthwhile to see if it helps.
But I have used the Lubegard, always as an additive though and have done so on our motor after replacing the torque converter, cleaning out the transmission cooler and pipes and replacing the filter in the gearbox.
Time will tell I suppose.
You can read some more here: http://www.lubegard.com/~/C-112/LUBEGARD+A...Protectant
Now I know they may be a bit biased, but some parts especially regarding the temperature test look interesting. As with most fluids the hotter it gets, the more it breaks down.
RRPhil would be someone better qualified with his opinion.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #297236 5th Dec 2014 7:42pm
rar110
I've just had a lifeguard flush & dr tranny added to my RR zf 6 speed with 230 thou I'm. It was good before but now a little smoother.
Post #297460 7th Dec 2014 11:38am
steptoe
Comments welcome
I can check the gearbox temp on my IID tool.
Post #297487 7th Dec 2014 1:25pm
Paul_H
England 2005 Range Rover Vogue Td6 Tonga Green
How easy is this to add to the gearbox without changing the ATF ?
Thanks 2005 Range Rover Vogue with Supercharged Accessories
GONE 2001 Discovery TD5 ES
GONE 1995 Discovery 300 tdi GS
Post #297493 7th Dec 2014 1:32pm
