![]() | Home > Maintenance & Mods (L322) > Lubeguard & Dr Tranny |
Have any of you high mileage guys heard of or used this stuff. They are highly recommending Dr Tranny as quick and effective fix for Torque Converter Judder and Lubeguard appears to be a good way of reducing transmission fluid temperate and with overheating being the arch enemy....
piecost76 Member Since: 19 Jul 2010 Location: Nr Sevenoaks, Kent Posts: 296 ![]() ![]() |
With both "Lube" & "Tranny" in the titles, am I the only one who thought this subject amusing?
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
No you are not piecost |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
They look and seem very good. I remember seeing something similar at the motor show a few years back, and it was a single shot type thing. On the surface it seemed very very good. The problem here is out gearbox's and TC are expensive and it's a big risk to use one of these types of products. RRPhil might have some input or know about these things. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Its a thread on the DISCO3 site they say Dr Tranny has cured a number of TQ judders completely.
hongkongphooey Member Since: 27 Aug 2010 Location: Douglas. Posts: 227 ![]() ![]() |
Sounds like a porn version of Dempsey and Makepiece. |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
I had something described as "redlube" additive put in when I had a gearbox flush and filter change. Seems to have done a god job so far. |
lex99 Member Since: 26 Sep 2013 Location: canada Posts: 3 ![]() |
would love rrphil's thoughts on this. |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
My gearbox has the odd shudder and sometimes feels like it is "slipping" if I accelerate hard from a lowish speed (i.e. roll up to a junction then give some gas). Are these products likely to improve the problem and if so how easy it to get to the fill point (i.e. can I just raise the suspension put some wooden blocks under the frame for security or do I need to put on a ramp etc... to access) I only have the factory jack which I know is not great and a 2.5T bottle jack that Im not sure I would trust on the FF.
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
A garage tried the shudder gear in my TD6 a few years ago, it didn't make any difference.
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 ![]() ![]() ![]() |
I suppose once a gearbox starts with the shudder symptoms, spending around £20 is worthwhile to see if it helps.
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I've just had a lifeguard flush & dr tranny added to my RR zf 6 speed with 230 thou I'm. It was good before but now a little smoother. |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
I can check the gearbox temp on my IID tool. |
Paul_H Member Since: 17 Dec 2013 Location: Bracknell Berks Posts: 126 ![]() ![]() ![]() |
How easy is this to add to the gearbox without changing the ATF ?
