![]() | Home > Maintenance & Mods (L322) > Removal of rear Wiper/washer Motor: How To with Pics |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 ![]() ![]() ![]() |
You're Welcome.
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 789 ![]() ![]() ![]() |
It can be fixed! The plastic piece where the tube is connected can be removed and inside theres a 10x16x4 simmerring that costs less than 1euro and that can be replaced. Then the plastic support that originally was thermally fitted can be simply attached with 4 screws. This way one can change the simmerring anytime. If needed I can post pictures. |
If you could that would help because personally I don't understand the word 'simmering' in this context, could you explain that some more? Discovery 4 HSE
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3756 ![]() ![]() |
perhaps its a shim ring?? |
Maybe I haven't got the english name right, a simmerring is a rubber radial joint with a spring in it that allows rotation while insulating, here's a picture: |
delsilencio Member Since: 08 Apr 2009 Location: toulouse Posts: 116 ![]() ![]() ![]() |
..and thatīs the inner view of what happens when inner seal ring is not longer leak-proof and why wiper stops working....(not much difference to old Lucas wiper motors from the 50s, but this wiper motor is from 2003)
Here's the motor with the new 1EUR seal ring and 4 screws holding the plastic piece. No more leaks!
Yet another satisfied customer |
adara, which seal ring do you mean?
The seal ring is inside the plastic piece here:
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
I have yet to do this repair however I will be going down a different route but thought I would share it here.
bristols Member Since: 14 Jun 2010 Location: California Posts: 1 ![]() ![]() ![]() |
Hello from California - extremely useful info, thnx, have to tackle my rear wash/wipe next week and now know what to expect |
markdotreed Member Since: 05 Sep 2011 Location: Ropley Posts: 741 ![]() ![]() |
After a quick search this was of great help and made a job that I thought would be hours a 20 minute breeze.
WAZZY786 Member Since: 26 Nov 2011 Location: NEWCASTLE Posts: 26 ![]() ![]() ![]() |
Hi guys has anyone found the cheapest place to use for buying the motor? Mine's gone - leaking into the rear trim |
