Home > Maintenance & Mods (L322) > Removal of rear Wiper/washer Motor: How To with Pics
Page 3 of 6 <123456>
You're Welcome.
Another satisfied customer! Thumbs Up Discovery 4 HSE
Post #7650 7th Oct 2009 1:34pm
ENVOY
United Kingdom 2003 Range Rover Vogue Td6 Java Black
Excellent post Thumbs Up
I have to change mine next week as it is doing the same as your was doing, i will do it rather than the garage as it seems quite straightforward
Post #8854 28th Nov 2009 6:51pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
It can be fixed! The plastic piece where the tube is connected can be removed and inside there’s a 10x16x4 simmerring that costs less than 1euro and that can be replaced. Then the plastic support that originally was thermally fitted can be simply attached with 4 screws. This way one can change the simmerring anytime. If needed I can post pictures.
Post #12371 4th Feb 2010 11:33am
If you could that would help because personally I don't understand the word 'simmering' in this context, could you explain that some more? Discovery 4 HSE
Post #12372 4th Feb 2010 11:58am
Vogue
perhaps its a shim ring??
Post #12373 4th Feb 2010 11:59am
adara
Maybe I haven't got the english name right, a simmerring is a rubber radial joint with a spring in it that allows rotation while insulating, here's a picture: [/img]
Post #12399 4th Feb 2010 7:46pm
delsilencio
France 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
..and thatīs the inner view of what happens when inner seal ring is not longer leak-proof and why wiper stops working....(not much difference to old Lucas wiper motors from the 50s, but this wiper motor is from 2003)
 XJC, RRV8, Series1 86 and 107% of real pleasure
Post #12991 11th Feb 2010 4:42pm
adara
Here's the motor with the new 1EUR seal ring and 4 screws holding the plastic piece. No more leaks!
Post #13021 11th Feb 2010 8:47pm
Yet another satisfied customer Thumbs Up Discovery 4 HSE
Post #13022 11th Feb 2010 8:48pm
delsilencio
adara, which seal ring do you mean?
The same as me( inside where to click the waterpipe into the adaptor for the jet, the small rubber ring) or the one in the upper tailgate where the complete wiper spindle goes through?
Post #13030 11th Feb 2010 10:05pm
adara
The seal ring is inside the plastic piece here:
You have to remove the plastic part completely (it is thermally attached to the metal and inside you will find a 10x16x4 seal ring. After you replace the seal the plastic piece can be mounted easily back with 4 screws. It is the only critical area, where water under pressure must be contained.
Post #13041 11th Feb 2010 11:18pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
I have yet to do this repair however I will be going down a different route but thought I would share it here.
The plan is, and I have forgotten where I read this but it sounds properly feasible and prevents future repeat issues and problems with the wiper motor.
Get a length of cuniffer (A copper alloy) brake line. Pop a small hole in one of the large rumer grommets that go through the tailgate and feed the pipe through. Profile the pipe such that it points out in a manner to put the water jet where you desire it, but will be hidden from view by the trim when replaced. Crush the end of the pipe to get a spray effect rather than a dribble (like you do owhen you pinch the end of a garden hose). Mole grips or pliers if you are "ard" Rolling Eyes . Attach the rubber hose to the brake line inside the car and suitably secure the fitting to prevent any irriitating rattle or such like.
Ok its a bodge. But its never going to be seen by anyone and should not fail due to being so simple!
If you don't have brake line as it is generally sold on a roll then ask a local garage. In fact they may do it all for you following these instructions as it really is simple.
Post #14672 10th Mar 2010 10:55am
bristols
United States 2004 Range Rover HSE 4.4 V8 Buckingham Blue
Hello from California - extremely useful info, thnx, have to tackle my rear wash/wipe next week and now know what to expect
Post #20033 14th Jun 2010 4:50am
markdotreed
After a quick search this was of great help and made a job that I thought would be hours a 20 minute breeze.
Cheers Regards
Mark
2009 D4; 1993 Classic 3.9 VSE
Post #88667 24th Oct 2011 8:06am
WAZZY786
United Kingdom 2006 Range Rover Vogue TDV8 Stornoway Grey
Cheapest place to buy new motor from?
Hi guys has anyone found the cheapest place to use for buying the motor? Mine's gone - leaking into the rear trim Sad so needs replacing - been a week of problems with the RR!arghhhh!!
The part's not cheap - my local LR service centre is rubbish - about as much use as a chocolate fireguard. Try and order parts from them but they're rubbish. Anyone recommend somehere?I'm based in Newcastle.
Cheers
Asim
Post #102361 19th Jan 2012 1:54am
