Home > Maintenance & Mods (L322) > Removal of rear Wiper/washer Motor: How To with Pics |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6370 |
You're Welcome.
7th Oct 2009 12:34pm |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 772 |
It can be fixed! The plastic piece where the tube is connected can be removed and inside theres a 10x16x4 simmerring that costs less than 1euro and that can be replaced. Then the plastic support that originally was thermally fitted can be simply attached with 4 screws. This way one can change the simmerring anytime. If needed I can post pictures. |
4th Feb 2010 10:33am |
If you could that would help because personally I don't understand the word 'simmering' in this context, could you explain that some more? Discovery 4 HSE
4th Feb 2010 10:58am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3747 |
perhaps its a shim ring?? |
4th Feb 2010 10:59am |
Maybe I haven't got the english name right, a simmerring is a rubber radial joint with a spring in it that allows rotation while insulating, here's a picture: [/img] |
4th Feb 2010 6:46pm |
delsilencio Member Since: 08 Apr 2009 Location: toulouse Posts: 116 |
..and thatīs the inner view of what happens when inner seal ring is not longer leak-proof and why wiper stops working....(not much difference to old Lucas wiper motors from the 50s, but this wiper motor is from 2003)
11th Feb 2010 3:42pm |
Here's the motor with the new 1EUR seal ring and 4 screws holding the plastic piece. No more leaks!
11th Feb 2010 7:47pm |
Yet another satisfied customer Discovery 4 HSE
11th Feb 2010 7:48pm |
adara, which seal ring do you mean?
11th Feb 2010 9:05pm |
The seal ring is inside the plastic piece here:
11th Feb 2010 10:18pm |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
I have yet to do this repair however I will be going down a different route but thought I would share it here.
10th Mar 2010 9:55am |
bristols Member Since: 14 Jun 2010 Location: California Posts: 1 |
Hello from California - extremely useful info, thnx, have to tackle my rear wash/wipe next week and now know what to expect |
14th Jun 2010 3:50am |
markdotreed Member Since: 05 Sep 2011 Location: Ropley Posts: 741 |
After a quick search this was of great help and made a job that I thought would be hours a 20 minute breeze.
24th Oct 2011 7:06am |
WAZZY786 Member Since: 26 Nov 2011 Location: NEWCASTLE Posts: 26 |
Hi guys has anyone found the cheapest place to use for buying the motor? Mine's gone - leaking into the rear trim so needs replacing - been a week of problems with the RR!arghhhh!!
19th Jan 2012 12:54am |
