![]() | Home > Maintenance & Mods (L322) > Removal of rear Wiper/washer Motor: How To with Pics |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
Ok. Took the plunge and just pulled the trim outwards as hard as I could. Came off with loud cracking noise but no broken clips |
destructimo Member Since: 24 Apr 2013 Location: Kent Posts: 76 ![]() ![]() ![]() |
Hi All,
CharlieBaja Member Since: 01 Feb 2016 Location: Surrey Posts: 52 ![]() ![]() ![]() |
Thank you very much for the helpful instructions with this job, very useful and lots of help. I only had a couple of isses and they were that the 12mm for the wiper was infact a 13mm and that once assembled for some mad reason the wiper caught the spoiler on its final sweep, however all sorted now and thanks again for the pictures and words.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Very chuffed that this is still helping people out |
crowebeard Member Since: 19 Dec 2016 Location: Devon Posts: 93 ![]() ![]() ![]() |
Thanks RRUK
MrSkill Member Since: 08 Nov 2012 Location: England Posts: 62 ![]() ![]() |
I just had the rear washer stop working and then water down the inside of the rear window.
johnb8538 Member Since: 15 Sep 2016 Location: Glasshoughton Posts: 71 ![]() ![]() ![]() |
Followed the guidance here and found everything working.... it was merely blocked nozzles!
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 801 ![]() ![]() ![]() |
I have just finished a refurb on my rear wiper motor after the gear stripped so thought I would add to this thread with a bit more info. The previous post advises fitting a shaft seal by removing the plastic water inlet. As this is plastic welded on it would need care to remove and then refitting is by self-tappers. I am sure it's a good fix but here is an option. On inspection from the inside, there is an o ring at the inner edge, the arrow in the quoted picture points to it. Mine had disintegrated and was the obvious reason for the leak and subsequent seizure. After trial and error, I found a 16mm x 9mm oring fits into the recess and seals against the shaft perfectly. I tried it up to 10psi and no leak. It takes a bit of teasing to get into the grove but easy enough and no need to interfere with the inlet. I have a bag of 50 if anyone in Perth wants one in the future. The replacement for the gear which was stripped I got from eBay however not the one listed for the L322. I discovered that a Mini Cooper rear motor gear is the same for half the price. I can confirm its a perfect match. 2007 TDV8 VSE 2003 TD6 gone. 2002 P38a gone 1999 P38a gone 1997 p38a gone 1993 VSE gone 1992 VSE gone 1966 Series 2a with V8 conversion gone |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
Yay! More cheaper part crossovers and another fix. |
A couple of pics to show what happens after the washer fluid has leaked into the gears and caused them to seize. The steel worm drive will still turn and strip the white plastic gear. Wiper still might move until it reaches the stripped section.
bleeperman Member Since: 01 Nov 2012 Location: lancs and Anglesey Posts: 109 ![]() ![]() |
Yep mine was the same another legendary LR design. Done the plastic gear and mine still will not park so I reckon the little electronic PCB has proved water and electric don't mix. I rerouted my pipe and it now exits under the spoiler and does a reasonable job. TBH kind of like cleaning the wiper blade when it parks mid screen! |
Tomo676 Member Since: 07 Aug 2018 Location: Aberdare, South Wales. Posts: 51 ![]() ![]() ![]() |
Well, I stripped my rear wiper motor down, got the oil seal washer from e-@@y. put it all back together and it works great. Thanks for posting this thread, it's saved me ยฃ200. I am well happy.๐๐๐ |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4328 ![]() ![]() ![]() |
I need to remove my trim. What do folks mean by pulling it โstraightโ to remove?
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
Just pull directly towards you, away from the tailgate (given you are both in line)
