Home > Technical (L322) > CANBUS ERROR
Rockportpurple
2002 Range Rover Vogue 4.4 V8 Giverny Green
CANBUS ERROR
hi all well the vogue doesnt disappoint at all after coming home from the garage for the 8th time the past week the hdc light comes on abs light,, air suspension light,engine failsafe mode,trans fail mode,i can run it for a few days no issues what so ever,,then poing engine failsafe,or transfailssafe, the potentiometer changed,new battery fitted blah blah,
its getting beyong a joke now its going back into the garage wednesday to have a full ecu reflash as when the lights come on i immediatly drive it to my garage when they put it on diag its coming up with canbus connection errors now,just what is this?
the mechanic says he has spoken to landrover who subjest a full ecu restore take all the things out of the ecu and download new software into the ecu,when we clear the faults comin up turn the ignition and try the car nothing,, drive it home then next day poing faults again,i have just taken my son home to his mums havnt used the car since friday turn the key,,,poing hdc,abs,no air suspension,drop my son off turn the key poing trans fail safe no sport mode no indication of wether in P,D,R,N etc,,turn the car off back on no problems car drives fine, Censored so can anyone please shed any more light on this issue as i know when i take my eldest to school in the morning ,,,poing something will come up just want to have complete peace of mind motoring,,have to say this has been a very rubbish range rover compared to my supercharged sport,its leaps and bound in front of a vogue to me if you distant yourself from the wag mobile,,,
if anyone has any other ideas please contact me before wed before it goes back for the umteen time
sometimes i have egg on my face as when i arrive to the garage turn it off back on again diag plugged in shows nothing on the diag machine no faults are stored etc
please please can someone help me before i crush the car Big Cry
regards
clive
Post #143834 30th Sep 2012 9:55pm
Brian GOG
United Kingdom 2002 Range Rover HSE Td6 Epsom Green
Hi Clive
Just had a look through some of your previous posts, the 02 - 04 RR had lots of different electrical systems working at the same time from BMW, LR and own ECU manufacturers software but from what you have written above the CAN Bus communication between the ECUs is causing the main problem. How far has your garage gone into checking the CAN Bus connections and splices. Generaly the ECUs are ok it's the wriring to them thats at fault. If you could let me know your exact vehicle details I will try and help some more. You can email them over to me on brian@greenovalgarage.co.uk.
Hope I can help
Brian
Green Oval
Post #143847 30th Sep 2012 10:43pm
The Brains Trust
Australia 2003 Range Rover HSE Td6 Adriatic Blue
Re: CANBUS ERROR
Rockportpurple wrote:
.. just want to have complete peace of mind motoring...
Maybe buy a Honda??? Seriously though, what year is it? My 03 throws the odd CAN bus fault, and the HDC becomes inactive. I just clear the fault and go again, but it only comes up once in a while, not all the time. Thinking at some stage I need to check the wiring and all the connections on the CAN. In general, CAN (Controller Area Network) is a very stable platform, and most of the errors I see with them (In genset engine control that I work with) are caused by wiring faults. The CAN continually checks the data it is sending and recieving and if it sees an error in the data transfer, or no data transfer, it will throw a fault. It could be a tiny dry joint opening up due to vibration, etc and could be hard to track down. You may need a very accurate wiring diagram showing where all connections on the CAN are - and there are plenty. On the 03 I think there are 7 ECU's connected on the main CAN.
I think the CAN on the Rangie is run as a 'free topography' system, so there doesn't need to be a start or end point like on some systems. The CAN wiring can be tapped into at any part of the system, so there may be no logical route to the wiring.
Cheers - Gav
Post #143856 1st Oct 2012 5:43am
Dolphinboy
Check inside your ABS module as they can get green corrosion on the "tongues" and disrupt the signal - as the ABS is in line with al the other sensors it throws up errors in all those too. I found a little bit of corrosion on my ABS module which threw up trans fail safe mode, hdc, restricted power etc etc. took it to .Lr dealer and they said new ABS module required ( at £1000!). Took it apart, cleaned mine with air hose and brush and everything back to normal and no recurrence!
Post #143869 1st Oct 2012 8:17am
ebajema
I noticed similar issues were discussed on the BBS forums (they make the Faultmates) and damages wiring is another issue that can screw up the CAN bus system.
Not sure if you can get onto their forums without a user account but you can maybe ask them http://www.blackbox-solutions.com/
Have you tried the CAN bus reset ?? Remove both battery clamps from the battery, hold them together for at least 2 minutes to fully reset the ECUs and see if that helps. MY 2010 5.0 SC Galway green and sand interior!!
Post #143896 1st Oct 2012 10:01am
Rockportpurple
hi guys thankyou for all your replies unfortunatly i didnt know you had replied as my email has bern down the car goes into the garage in the morning but i might delve into the abs module and have a look tonight,today i had just select gears again and no tip tronic so its going back for a replacement gear selector under warranty i bought to see if that cures that fault still coming up,after my reset ecu tomorrow with new software i will update you and let you know
regards
clive
Post #144290 2nd Oct 2012 6:06pm
Rockportpurple
update
hi guys well got the car today after two days at the garage it was diag as a faulty potentiometer switch
so new one fitted on the car dorve it home around 23 miles,,on the way to pick up the kids,,poing,,hdc light engine failsafe,abs light,dsc light,air sus inop,hdc inop,,turned the car of at school waited switched it back on,,no issues,to the other school to pik up my youngest,no issues,,rang the garage arranged it the car to go back on diag,at 4.30 this afternoon on the way to the garage poing,,,trans overheat,limited gears only 3,sometimes 2,,placed on diag,threw up everything,reset it all with diag,took it out for a test drive,no issues wrote down the diag codes to speak to land rover tomorrow
left the garage got into 15miles of driving poing,,nothing showing but only 3 gears to drive the other 8 miles into town very annoying at 4k at 50mph,,in 3rd gear,,shunting into 1st on slowdown, Big Cry
does anyone have any other solution apart from a match? Censored
regards
clive
Post #144758 4th Oct 2012 10:52pm
Rockportpurple
hi guys
well thankyou moderator for locking my new thread asking for more advice frim generous guys on here trying to help with my issues,,thankyou very impressed by the pettyness i need help and fast!
right rant over the car is now driving around 20miles and then will not give me a warning poing or anythin?
it will only travel up to 3rd gear then change down violently,then rev and rev then decide to only go up to 3rd gear
has anyone got any other advice
please help
regards
clive
Post #145365 8th Oct 2012 6:52pm
I can sense your frustration, but having a go at people on a forum where you're "needing help and fast" could prove more than a little counter productive! Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #145366 8th Oct 2012 7:09pm
sorry you feel that locking your other thread [with the same question] is petty but as i have said , you will probably get the same suggestions if members cant see your existing thread and whats been said already....
so you have 25 posts and you havnt made any contribution to the forum ..you've only asked questions to your problems but dont get me wrong , we dont mind helping ,if we can... ... - .- -.
Post #145368 8th Oct 2012 7:35pm
Shocked Whistle Whistle
Post #145374 8th Oct 2012 8:10pm
Rockportpurple
thankyou for your reply stan if i can help the forum in anyway then i will and contribute to it but to start a new thread to seek some answers rather urgently i didnt think was an issue to reach a conclusion
with different issues with the car hoping that someone could shed some light on the issue,,
so my car has faulted 25 times surely this forum is to gather information from other owners experiences and is a question of process off elimination?
in no way shape or form was ' i having a go at other members on this forum' so id appreciate that part deleting please,compared to other forums i have joined this is an exclusive one with some very good pointers and i value there opinion
the car is going into the garage for throttle bodies and throttle pedal next to be looked at on wed,,and the fault might lie in the loom in there,i think myself it is still gearbox related but i honour all members opinions and look forward to a reply if possible,,stan i think this site is of great benefit as was the rrs forum and discovery one too but to lock my thread to me was petty and i think everyone is entitled there opinion without offence, Confused
regards
clive
Post #145427 8th Oct 2012 9:45pm
