![]() | Home > Technical (L322) > CANBUS ERROR |
Brian GOG Member Since: 08 Dec 2011 Location: leeds Posts: 57 ![]() ![]() ![]() |
Hi Clive
The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155 ![]() ![]() ![]() |
Maybe buy a Honda??? Seriously though, what year is it? My 03 throws the odd CAN bus fault, and the HDC becomes inactive. I just clear the fault and go again, but it only comes up once in a while, not all the time. Thinking at some stage I need to check the wiring and all the connections on the CAN. In general, CAN (Controller Area Network) is a very stable platform, and most of the errors I see with them (In genset engine control that I work with) are caused by wiring faults. The CAN continually checks the data it is sending and recieving and if it sees an error in the data transfer, or no data transfer, it will throw a fault. It could be a tiny dry joint opening up due to vibration, etc and could be hard to track down. You may need a very accurate wiring diagram showing where all connections on the CAN are - and there are plenty. On the 03 I think there are 7 ECU's connected on the main CAN. I think the CAN on the Rangie is run as a 'free topography' system, so there doesn't need to be a start or end point like on some systems. The CAN wiring can be tapped into at any part of the system, so there may be no logical route to the wiring. Cheers - Gav |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
Check inside your ABS module as they can get green corrosion on the "tongues" and disrupt the signal - as the ABS is in line with al the other sensors it throws up errors in all those too. I found a little bit of corrosion on my ABS module which threw up trans fail safe mode, hdc, restricted power etc etc. took it to .Lr dealer and they said new ABS module required ( at £1000!). Took it apart, cleaned mine with air hose and brush and everything back to normal and no recurrence! |
I noticed similar issues were discussed on the BBS forums (they make the Faultmates) and damages wiring is another issue that can screw up the CAN bus system.
Rockportpurple Member Since: 04 May 2012 Location: Scarborough Posts: 38 ![]() ![]() |
hi guys thankyou for all your replies unfortunatly i didnt know you had replied as my email has bern down the car goes into the garage in the morning but i might delve into the abs module and have a look tonight,today i had just select gears again and no tip tronic so its going back for a replacement gear selector under warranty i bought to see if that cures that fault still coming up,after my reset ecu tomorrow with new software i will update you and let you know
hi guys well got the car today after two days at the garage it was diag as a faulty potentiometer switch
well thankyou moderator for locking my new thread asking for more advice frim generous guys on here trying to help with my issues,,thankyou very impressed by the pettyness i need help and fast!
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6770 ![]() ![]() ![]() |
I can sense your frustration, but having a go at people on a forum where you're "needing help and fast" could prove more than a little counter productive! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35653 ![]() ![]() |
sorry you feel that locking your other thread [with the same question] is petty but as i have said , you will probably get the same suggestions if members cant see your existing thread and whats been said already....
thankyou for your reply stan if i can help the forum in anyway then i will and contribute to it but to start a new thread to seek some answers rather urgently i didnt think was an issue to reach a conclusion
