Home > Technical (L322) > Rear Door - Water Trapped between inner & outer seal
GTJones
Wales 2002 Range Rover Vogue Td6 Epsom Green
Not sure if anyone has experienced this problem but if i open the rear passenger door after it has rained i get a large amount of water come out, it looks as if it is trapped between the inner & outer door seals as there is no water in the car?
Checked the drain holes on the bottom of the door and they look clear also the seals are in good condition Confused
Can't understand why it is getting trapped, any advice would be helpfull
Gary
Post #141548 17th Sep 2012 12:13pm
It's a common problem. Don't believe any solution has yet been found. Crying or Very sad
For me, it only ever seems to be on the drivers side rear this happens.
Only comforting thing is that if it can't get out at the bottom of the door, it can't get in there either. probably coming in way above any wading height. Smile .
Post #141556 17th Sep 2012 12:53pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
I'm sure that Stan posted a cure fairly recently involving wedging a piece of 2x4 in the bottom of the door and gently pushing the top closed (possibly with the window open) - but my searching skills in the forum and wiki aren't up to much since I can't find it now.
Post #141568 17th Sep 2012 1:58pm
I posted that and it works. Thumbs Up
Takes a few minutes and never had a problem since.
Post #141569 17th Sep 2012 2:01pm
VaguelyVogue
Whoops - apologies !
So where is the link then ? Very Happy
Post #141570 17th Sep 2012 2:01pm
No idea, I just can't find it. Smile
Edit : Found it Thumbs Up
http://www.fullfatrr.com/forum/topic12101.html?highlight=water
Post #141573 17th Sep 2012 2:21pm
wasnt me VV, my solution was to drill two 1'' diameter holes on the outside of the door to let the water out... Mr. Green ... - .- -.
Post #141584 17th Sep 2012 2:49pm
GTJones
Re: Rear Door - Water Trapped between inner & outer seal
Gary
Hi Joe
Same location - Rear Off Side door - will have a look at the fix but must admit don't fancy driving around with a bit of 4"x"2 jammed in the door Wink
Gary
Post #141591 17th Sep 2012 3:21pm
Coastal
England 2015 Range Rover Autobiography SDV8 Barolo Black
I also have this on my 5.0 SC 2010 on offside door only.
Does anyone know of a video showing the block of wood and hang off the door trick to form the door slightly to stop this?
Post #355240 3rd Nov 2015 11:32pm
Zirconblue
i had it, replacing the water shedders behind the door cards seems to have cured it.
Post #355244 3rd Nov 2015 11:48pm
Not something I'd recommend you try first time on a door that will cost an arm and a leg to replace, very easy to go too far and do permanent severe damage to it, get a bodyshop to do it, they do it all the time when fitting new doors... Pete
Post #355250 4th Nov 2015 12:28am
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Its the membrane behind the door card that is the cause, if you look closely when it's been raining you will more than likely see a trickle of water coming from the door card.... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #355262 4th Nov 2015 7:38am
Zirconblue
yep thats exactly what i had. the newer water shedders are a slighly different design.
Post #355294 4th Nov 2015 10:24am
Coastal
Thanks chaps. I'll take a look at the door card and shredder.
Post #355337 4th Nov 2015 7:00pm
You will have the later water shedder, it's more likely to be the problem mentioned above...
Worth a look at it first though... get the hose on the bottom edge of the window for 5 mins and see if the door gap fills up, if it doesn't get the hose along the door/roof seam and see if it fills up.... Thumbs Up Pete
Post #355359 4th Nov 2015 8:57pm
