Home > Technical (L322) > Rear Door - Water Trapped between inner & outer seal |
GTJones Member Since: 23 Aug 2012 Location: Carmarthenshire Posts: 35 |
Not sure if anyone has experienced this problem but if i open the rear passenger door after it has rained i get a large amount of water come out, it looks as if it is trapped between the inner & outer door seals as there is no water in the car?
17th Sep 2012 12:13pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
It's a common problem. Don't believe any solution has yet been found.
17th Sep 2012 12:53pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
I posted that and it works.
17th Sep 2012 2:01pm |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 |
Whoops - apologies !
No idea, I just can't find it.
17th Sep 2012 2:21pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35281 |
wasnt me VV, my solution was to drill two 1'' diameter holes on the outside of the door to let the water out... ... - .- -.
17th Sep 2012 2:49pm |
Hi Joe Same location - Rear Off Side door - will have a look at the fix but must admit don't fancy driving around with a bit of 4"x"2 jammed in the door Gary |
17th Sep 2012 3:21pm |
Coastal Member Since: 30 Oct 2015 Location: Thanet Posts: 7 |
I also have this on my 5.0 SC 2010 on offside door only.
3rd Nov 2015 11:32pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
i had it, replacing the water shedders behind the door cards seems to have cured it. |
3rd Nov 2015 11:48pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8192 |
Not something I'd recommend you try first time on a door that will cost an arm and a leg to replace, very easy to go too far and do permanent severe damage to it, get a bodyshop to do it, they do it all the time when fitting new doors... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
4th Nov 2015 12:28am |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 |
Its the membrane behind the door card that is the cause, if you look closely when it's been raining you will more than likely see a trickle of water coming from the door card.... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
4th Nov 2015 7:38am |
yep thats exactly what i had. the newer water shedders are a slighly different design. |
4th Nov 2015 10:24am |
Thanks chaps. I'll take a look at the door card and shredder. |
4th Nov 2015 7:00pm |
You will have the later water shedder, it's more likely to be the problem mentioned above...
4th Nov 2015 8:57pm |
