Home > Maintenance & Mods (L322) > Visit to gearbox specialist this week, any questions? |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1518 |
Great news Craig. Any comment about the 6 speed?
30th May 2012 8:48pm |
Cheers!
30th May 2012 9:15pm |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
Interesting, the one which failed on my car must have been the exception then, it never had a tow bar! Range Rover-less at the moment - Pining! |
30th May 2012 9:25pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Oh here we go again!!!
30th May 2012 10:41pm |
Funny reaction to an innocent observation? Sorry if I offended Craig, just stating fact based on my direct experience.
31st May 2012 9:37am |
Really! Hmmm...
18th Aug 2012 10:56pm |
ikilla2 Member Since: 22 Jul 2012 Location: England Posts: 72 |
Craig, who is gearbox specialist? |
19th Aug 2012 6:37am |
dannyp15 Member Since: 21 Sep 2011 Location: essex Posts: 244 |
im still on the fence about getting mine done im on 100k now and the gearbox seem fine
19th Aug 2012 6:44am |
Seems nobody asked the most pertinent question then.
19th Aug 2012 6:50am |
Is this on the 5 or 6 speed box please? Craig |
19th Aug 2012 6:55am |
There was/is a problem with some Mercedes and glyco contamination, from memory the main cause was Valeo radiators and coolers leaking causing cross contamination. Never heard of a FFRR having this problem though |
19th Aug 2012 7:10am |
Both I believe Craig. Basically, any car which has the transmission fluid cooler in the main radiator will be susceptible to this. Radiators have a finite life and when they do let go quite a lot do so between the water and oil parts. Quite a common pre-emptive thing is to fit an ali rad, or a separate gearbox oil cooler.
Have personally seen 4 now. EDIT. From memory, all were either 56 plate or 07 which would make them 6 speeds. |
19th Aug 2012 7:19am |
Correct me if im wrong but my gearbox cooler is separate to the water rad im sure...
19th Aug 2012 7:48am |
They rebuild all my customers gearboxes... Just did my TD5 pickup... Craig |
19th Aug 2012 8:26am |
