![]() | Home > General > Torture filling up with diesel |
Turn the nozzle upside down |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
+1 for inverting the nozzle, fuels much better |
smartymarti Member Since: 01 Aug 2012 Location: Durham Posts: 32 ![]() ![]() ![]() |
Many thanks will try that tomorrow |
Slick Member Since: 05 Jun 2011 Location: Where No One Can Hear You Scream Posts: 22 ![]() ![]() |
Are you sure it's not the fuel guard ? There's a flap thing that can sometimes be partially engaged and needs resetting. Ebay - solves all your problems |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
As above, turn to the 9 o'clock position, fuels no problem. |
Try this thread and the photo on page 2 Ebay - solves all your problems |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
If you can see a yellow flap, then it is the mis-fuel flap preventing the diesel going in, you need to reset it. Turning the fueling nozel upside down may help but will not fix the problem 56 TDV8 Vogue SE
I can see the yellow flap , pulled the reset but nothing happened and I don't wanna pull it to hard incas it snaps |
I reset mine by gently pushing the yellow flap with the end of a 3 ft breaker bar as the landrover tool supplied with the car only moved it to a sort of half set position 56 TDV8 Vogue SE
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 ![]() ![]() ![]() |
Another +1 for upside down filling.
Muddywheels Member Since: 18 Jun 2012 Location: East Riding of Yorkshire Posts: 394 ![]() ![]() |
I find if you keep the nozzle high so not down the neck too far works fine on mini and RRS - if I put it right in shuts off on both and on fl1 I used a quarter turn |
m3mjw Member Since: 10 Feb 2012 Location: Sunderland Posts: 118 ![]() ![]() ![]() |
I was also having this issue. Thanks for upside down tip - works for me |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2663 ![]() ![]() |
A nice firm shove works well too! |
