Home > Technical (L322) > 2006 4.2 supercharged cut out and wont start
Can you pull a fuse on the Lpg to take that out the picture? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #131768 18th Jul 2012 10:52am
Alexdyer
It turns over just fine i have flattened the battery now but it is back on charge now. Like I said it has a spark compression and the plugs were wet with fuel so I am stumped!
Post #131781 18th Jul 2012 11:51am
Alexdyer
My lpg guy is coming tonight so fingers crossed he can shed some light on it
Post #131783 18th Jul 2012 11:53am
good luck mate.. Thumbs Up ... - .- -.
Post #131786 18th Jul 2012 11:58am
Alexdyer
Failing me finding the problem does anyone know of a range rover specialist in my area maidstone in kent?
Post #131791 18th Jul 2012 12:04pm
Alexdyer
Right here we go!
My LPG guy has been round and we have deduced that the lpg's ecu is fried and is dual fuelling!
With the petrol supply pipe clamped we can run on gas as great as you like. If you pull the lpg out of the equation it runs also just on petrol.
So new ecu to stop the twin fuelling and also a new battery as a precaution!
As thinking back I had the screen say reduced power a week or so ago.
Will update with the final findings and hopefully a resolution!
Thank you for all of the input so far.
Back soon!,
Post #131879 18th Jul 2012 8:08pm
Congrats pal... Glad you got it sorted, would never have thought that was possible...
Craig Whistle
Post #131915 18th Jul 2012 10:44pm
Alexdyer
Ok the saga continues!
The LPG Ecu was tested on another car and there was no problem with it!
So today I pulled the intake off the top of the s/c when I disconnected the vacuums pipe from the intake to the back of what must be a fuel rail pressure sensor combined with a vacuumed sensor. It flooded out fuel!
Turned the ignition on to 2nd position and fuel streamed out of the vacuums pipe.
So as far as I can see the fuel rail pressure sensor failed and let fuel bypass into the throttle body causing it to dual fuel! This can be the only way it can fuel if the LPG system is working correctly.
I am pulling the s/c off tomorrow as it has had a small bearing grumble so will let you all know the outcome once I have had it rebuilt.
Talk soon guys
Post #132063 19th Jul 2012 8:23pm
Alexdyer
Has anyone got the procedure to remove the throttle body from the s/c? Is there a bracket beneath or something.
Post #132068 19th Jul 2012 8:52pm
Alexdyer
well after all finally repaired!
Fitted a new SC unit from landrover and all is well.
Untill the next thing!!
If anyone needs any advise on replacing a SC I am now pretty confident on giving advise on the removal and installation.
thanks for everyones input.
Post #137415 23rd Aug 2012 1:43pm
