![]() | Home > Technical (L322) > Strange overheat problem 07 L322 HELP! |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
Have you checked the oil dipstick for signs of emolsification(SP)?
chim Member Since: 11 Jan 2012 Location: Ayrshre Posts: 11 ![]() ![]() |
Checked oil, all clear with no signs of emulsification at all. The revs are odd, it sounds as if it is revving while not in gear but I am still getting some drive although reduced, foot of the throttle it drops revs as normal. No fault lights but as mentioned starts to overheat quickly. RRFF 2007 |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6773 ![]() ![]() ![]() |
Well as it's obviously a she, maybe it's "that time"? |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Check the gearbox oil for signs of emulsification or water in the oil.
When you top up the cooling system, do you remove the bleed screw on the header tank and how much water does it normally take to fill it?
