Home > Technical (L322) > Parking sensors
Johnte
Parking sensors
Would / could a faulty front sensor also stop the rears from working?
I'm getting the long tone when the parking sensors should be active. I've listened to them all, and one front one isn't 'ticking'
Thanks
Post #131362 16th Jul 2012 1:54pm
afaik they should be on separate circuits john.. but the front one isnt ticking then it or the wiring going to it is faulty... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
workshop manual downloads are in our wiki
Post #131365 16th Jul 2012 1:56pm
Johnte
Thought they would be separate, just seems strange how non are working ...
Post #131366 16th Jul 2012 1:59pm
that is strange..normally the fronts dont 'sense' until you have reversed or selected the rears...the front one is a good place to start .. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #131368 16th Jul 2012 2:01pm
tomthevet
Scotland 2005 Range Rover Vogue Td6 Tonga Green
When I had faulty rear loom neither front or rear worked though the good ones were ticking away.
Replaced rear loom and all work fine.
T
Post #131452 16th Jul 2012 6:19pm
Aurrian
2005 Range Rover Vogue SE Td6 Java Black
Same here.
If there is a fault on either front or back - you seem to get the error tone and none of them work.
Post #131463 16th Jul 2012 7:55pm
Squirrel
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Galway Green
My front parking sensors don't seem to be working and yet I don't get the error tone. The rear ones work fine. Maybe I'm doing something wrong?? I've tried putting the car in reverse first and getting someone to walk round the back and then the front. Back ones make beepbeeps, front ones don't.
I'll have to Investigate.
Post #131488 16th Jul 2012 8:52pm
the fronts wont work until you put it drive or press the parking sensor button. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #131490 16th Jul 2012 8:55pm
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
Front and rear sensors work on a separate circuit.
It sound like you have a sensor out at the front, you can check by switching the position in the front bumper. if the non clicking sensor moves to the new position it is the sensor, if not then it is the wiring loom. The front loom is part of the engine loom and therefore is very expensive to replace so i recommend repairing.
The front sensor become active when you press the button on the centre console or when you select reverse. See you owners handbook.
The result of the rear sensors not working maybe the PDC module being faulty. I would fix the front sensor first and see if everything is resolved. If not then a new module isn't that expensive and is an easy fix as it is just plug and play. 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #131518 16th Jul 2012 10:55pm
