Home > Technical (L322) > Strange overheat problem 07 L322 HELP!
chim
2007 Range Rover Vogue SE 4.4 V8 Zermatt Silver
Have a strange problem, well maybe not strange but odd. As soon as she starts heating up from cold its as if she is not catching a gear right and the revs just climb up, very quickly she then starts to overheat. On inspection I have found traces of coolant around the engine bay. When I have looked at the coolant bottle it has filled right up and then drains out as she cools with a gurgle and need to top up. Suspect it might be the water pump but the not catching gear and high revs as the first symptom have me worried it might be autobox related. Any advice much appreciated. RRFF 2007
Post #131336 16th Jul 2012 11:06am
Budgie
Have you checked the oil dipstick for signs of emolsification(SP)?
With the collent header tank being full and then draining, it sounds like it's being pressurised which could indicate a head gasket.
Not clue with high revs & failure to change up though.
Does it do this on it's own, without any throttle input from you?
What happens when you take your foot off the throttle?
It sounds like the kickdown is in operation so could be ECU or throttle peddle related.
Any faults/lights showing on the dash?
Post #131337 16th Jul 2012 11:20am
chim
Checked oil, all clear with no signs of emulsification at all. The revs are odd, it sounds as if it is revving while not in gear but I am still getting some drive although reduced, foot of the throttle it drops revs as normal. No fault lights but as mentioned starts to overheat quickly. RRFF 2007
Post #131339 16th Jul 2012 11:28am
Well as it's obviously a she, maybe it's "that time"? Rolling Eyes Got - 2017 SDV8 Autobiography in Loire Blue
Post #131342 16th Jul 2012 11:47am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Check the gearbox oil for signs of emulsification or water in the oil.
Not heard this happening on a rangie, but on some cars a common failure mode is the gearbox oil pipes that go through the radiator (to control the temp of the gearbox oil) become perforated and the pressurised water ends up in the gearbox.
Post #131387 16th Jul 2012 2:54pm
Budgie
When you top up the cooling system, do you remove the bleed screw on the header tank and how much water does it normally take to fill it?
It could just need "burping" (have air trapped in the system somewhere).
Post #131437 16th Jul 2012 4:56pm
