Home > Technical (L322) > Will this key work with a l322?
Lifetime ban... Whistle
Post #126601 17th Jun 2012 7:05pm
enumbers
Ireland 2004 Range Rover HSE Td6 Adriatic Blue
I was going to fit the chip in one of the ebay blank keys I have so I can start the car if something happened the original key rather than paying landrover 300 euro for a new key.
Post #126602 17th Jun 2012 7:08pm
daveo
jeep Big Cry , yes you can use the chip but it will need to be coded, make sure you get the circuit board with the new key case, you can buy a used key just for the circuit board as this can be programmed to open and close the doors by yourself, not many dealers will program a key transponder [chip] if they have not supplied it,some will but most wont. V8 facelift Range Rover Autobiography 22" wheels.
Post #126633 17th Jun 2012 9:24pm
enumbers
sorry for the lack of etiquette would someone be as kind as to tell me the correct term so I can save myself from the horrible embarrassment of calling the beloved range rover a jeep 2004 td6 Adriatic Blue
Post #126783 18th Jun 2012 8:47pm
FFRR Thumbs Up
Post #126786 18th Jun 2012 8:57pm
piecost76
To be fair to the deleted by moderator , all 4x4's over there are generically called "Jeep"
Probably run on the Green too Wink Quis custodiet ipsos custodes?
15 MY 110 XS USW
54 FFRR Vogue TD6 Touchscreen - Gone!
56 FFRR TDV8 VSE - Gone!
Post #126812 19th Jun 2012 8:47am
enumbers
of course green its better for the environment Very Happy probably safer for the car to with the amount of washed diesel here. 2004 td6 Adriatic Blue
Post #126862 19th Jun 2012 4:06pm
The Brains Trust
Australia 2003 Range Rover HSE Td6 Adriatic Blue
Anyone here know what machine you need to program the new transponder chips? That has always been the biggest issue in getting a decent priced key... The key itself is easy, getting it to open the car is easy. Getting it to start it is near impossible... Crying or Very sad
Cheers - Gav
Post #128720 1st Jul 2012 10:11am
