Home > Technical (L322) > Will this key work with a l322? |
Lifetime ban... |
17th Jun 2012 7:05pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
jeep , yes you can use the chip but it will need to be coded, make sure you get the circuit board with the new key case, you can buy a used key just for the circuit board as this can be programmed to open and close the doors by yourself, not many dealers will program a key transponder [chip] if they have not supplied it,some will but most wont. V8 facelift Range Rover Autobiography 22" wheels.
17th Jun 2012 9:24pm |
enumbers Member Since: 12 Dec 2011 Location: South east Posts: 26 |
sorry for the lack of etiquette would someone be as kind as to tell me the correct term so I can save myself from the horrible embarrassment of calling the beloved range rover a jeep 2004 td6 Adriatic Blue |
18th Jun 2012 8:47pm |
FFRR |
18th Jun 2012 8:57pm |
piecost76 Member Since: 19 Jul 2010 Location: Nr Sevenoaks, Kent Posts: 296 |
To be fair to the deleted by moderator , all 4x4's over there are generically called "Jeep"
19th Jun 2012 8:47am |
of course green its better for the environment probably safer for the car to with the amount of washed diesel here. 2004 td6 Adriatic Blue |
19th Jun 2012 4:06pm |
The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155 |
Anyone here know what machine you need to program the new transponder chips? That has always been the biggest issue in getting a decent priced key... The key itself is easy, getting it to open the car is easy. Getting it to start it is near impossible...
1st Jul 2012 10:11am |
