![]() | Home > Technical (L322) > Drivers electric windows controls Help!! |
The Hitman Member Since: 28 Jun 2011 Location: Greenhithe Posts: 30 ![]() ![]() ![]() |
Hi Guys
Saint.v8 Member Since: 13 Jun 2012 Location: UK< Surrey - Near the Middle Close to Some Green Bits Posts: 94 ![]() ![]() ![]() |
If the individual door controls work...I would think it is not the door wiring, or motors or fuses....I suggest looking at the Drivers door switch pack.... |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Thanks guys |
First job is to take it off and check it over to be certain this is the problem. A fault code diagnosis may help also.
Thats gonna be first job in the morning to check it and give it a good clean up and check wiring etc...... was just wondering in case its needed how much?? and where from?? thats all i wanted to know just in case |
blench99 Member Since: 18 Nov 2011 Location: northumberland Posts: 24 ![]() ![]() ![]() |
this happened to me and its the wiring in the plug that goes into the driver's door. You need to remove the plug then it comes apart and you will prob find a couple of the very small pins either corroded of snapped. If they are snapped you will have to cut the said wires and solder them together.hope this helps, any prob's, give me a shout |
Thanks for the offer...
