Home > Technical (L322) > Drivers electric windows controls Help!! |
The Hitman Member Since: 28 Jun 2011 Location: Greenhithe Posts: 30 |
Hi Guys
22nd Jun 2012 12:19pm |
Saint.v8 Member Since: 13 Jun 2012 Location: UK< Surrey - Near the Middle Close to Some Green Bits Posts: 94 |
If the individual door controls work...I would think it is not the door wiring, or motors or fuses....I suggest looking at the Drivers door switch pack.... |
22nd Jun 2012 2:31pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
what Saint V8 says .
22nd Jun 2012 3:02pm |
Thanks guys
22nd Jun 2012 8:20pm |
First job is to take it off and check it over to be certain this is the problem. A fault code diagnosis may help also.
22nd Jun 2012 9:10pm |
Thats gonna be first job in the morning to check it and give it a good clean up and check wiring etc...... was just wondering in case its needed how much?? and where from?? thats all i wanted to know just in case Currently run a P38 yes i know I am mad but it helps and a 6.75 Bentley Turbo S and Now have a 2004 4.4 V8 vogue FFRR can life get any better...... |
22nd Jun 2012 9:45pm |
blench99 Member Since: 18 Nov 2011 Location: northumberland Posts: 24 |
this happened to me and its the wiring in the plug that goes into the driver's door. You need to remove the plug then it comes apart and you will prob find a couple of the very small pins either corroded of snapped. If they are snapped you will have to cut the said wires and solder them together.hope this helps, any prob's, give me a shout |
23rd Jun 2012 8:49am |
Thanks for the offer...
23rd Jun 2012 8:37pm |
