Home > Technical (L322) > RR 2003 Vogue V8 - Transmission fault on warm up |
Was it the gearbox sump gasket that was changed? |
14th Jun 2012 3:10pm |
rjp996 Member Since: 28 Apr 2009 Location: East Sussex Posts: 22 |
Just a thought - is the v8 gearbox oil fill procedure the same as the td6 one in that the final oil fill needs to be done whilst the engine is running to ensure the pump / torque converter are full. If so maybe low oil ??? But thats only a guess. |
14th Jun 2012 4:12pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 962 |
Assuming it was the gearbox sump gasket, was it the dealer who replaced this or an independent?
14th Jun 2012 4:31pm |
Exactly what I was thinking Phil |
14th Jun 2012 4:58pm |
rmackinnon Member Since: 14 Mar 2012 Location: Mansfield, UK Posts: 85 |
Excellent feedback! Thanks guys.
14th Jun 2012 8:19pm |
You need to make sure that they put this stuff, and only this stuff, in your transmission :
14th Jun 2012 10:11pm |
Great feedback. Thanks!
15th Jun 2012 8:51am |
quick question - i notice the oil is much cheaper online, i may buy a load ahead of Tuesday.
15th Jun 2012 9:10am |
10 litres from dry, but only half that for a 'drain then refill'
15th Jun 2012 9:15am |
Thanks Phil
15th Jun 2012 9:29am |
Quick update.
19th Jun 2012 8:43pm |
Hey all
21st Jun 2012 11:09am |
Hope this wasn't the same garage that did the filter and fluid change |
21st Jun 2012 12:30pm |
the dealer where i bought the RR was using a garage of their own. It seems they were cutting corners.
23rd Jun 2012 9:30am |
