![]() | Home > Technical (L322) > RR 2003 Vogue V8 - Transmission fault on warm up |
Was it the gearbox sump gasket that was changed? |
rjp996 Member Since: 28 Apr 2009 Location: East Sussex Posts: 22 ![]() ![]() ![]() |
Just a thought - is the v8 gearbox oil fill procedure the same as the td6 one in that the final oil fill needs to be done whilst the engine is running to ensure the pump / torque converter are full. If so maybe low oil ??? But thats only a guess. |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
Assuming it was the gearbox sump gasket, was it the dealer who replaced this or an independent?
Exactly what I was thinking Phil |
rmackinnon Member Since: 14 Mar 2012 Location: Mansfield, UK Posts: 85 ![]() ![]() ![]() |
Excellent feedback! Thanks guys.
You need to make sure that they put this stuff, and only this stuff, in your transmission :
Great feedback. Thanks!
quick question - i notice the oil is much cheaper online, i may buy a load ahead of Tuesday.
10 litres from dry, but only half that for a 'drain then refill'
Thanks Phil
Quick update.
Hey all
Hope this wasn't the same garage that did the filter and fluid change ![]() |
the dealer where i bought the RR was using a garage of their own. It seems they were cutting corners.
