Home > Technical (L322) > getting away without a torque wrench |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 |
Hi folks,
10th May 2012 8:46am |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
All depends how used to spannering you are!
10th May 2012 8:50am |
stuboy00 Member Since: 09 Feb 2012 Location: Glasgow Posts: 251 |
Wouldn't normally use a torque for the rocker cover just tighten then give it a jag up only use a torque for the head that's my experience anyway but others may disagree
10th May 2012 8:53am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35270 |
normally a tighten and then a quarter turn should be ok... ... - .- -.
10th May 2012 10:46am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3779 |
If you intend doing more DIY maintenance then buy the wrench, I bought one just to torque up my wheel nuts. Most of my life I've done workarounds/bodges due to not having the right tools - I now realise it was a mistake
10th May 2012 10:57am |
Thanks for the advice gentlemen. I will just go with nipping it up for now. MY2010 TDV8 Vogue Ipanema Sand
10th May 2012 11:21am |
10ft lbs is nothing more than just nipped up and no more. |
10th May 2012 11:22am |
There is a proper torque scale for people without a torque wrench...
10th May 2012 11:48am |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 |
You can paypal direct using - www.paypal.me/duckworthparts
10th May 2012 11:53am |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Previously..
10th May 2012 1:06pm |
Cheers for reply folks. I changed the rocker covers and rubber washers last week. I even managed to loose one of the nuts and had to get one from land rover for the princely sum of 3.85... I'm watching both closely now to check the leaks have gone. MY2010 TDV8 Vogue Ipanema Sand
17th May 2012 3:39pm |
