Home > Technical (L322) > Fan orange light always on....... |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7815 |
I've just noticed that I have a single orange light, always lit, from around the "rotary encoder" on the fan speed control.
28th Apr 2012 3:08pm |
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 |
Whats your battery life like? The fan speed indicator fault is a sure sign that the heater fan speed control (resistor pack -aka the hegehog) is faulty. It causes other problems including rapid battery drain. The little red light on the transmission position should extinguish ten mins after the car has been locked. To check, look through the window, dont unlock or open the door.
28th Apr 2012 10:01pm |
Cheers.
29th Apr 2012 7:59am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8622 |
Ooh. better hope its not the control pack, just had mine replaced, cost warranty 600+ for the part. There is nothing that can't be fixed with a hammer😜😜
29th Apr 2012 9:21am |
Just removed the fuse (F12 Passenger Compartment), and replaced, and the light is still on.
29th Apr 2012 10:23am |
Resist..... Expensive part, which works, to spanner apart, for a little orange light. There is nothing that can't be fixed with a hammer😜😜
29th Apr 2012 3:03pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
Is this the 'Triggers Broom' version of the FFRR? Certainly getting your pennies worth from that warranty, good on yer |
29th Apr 2012 3:42pm |
Nah, im just a bit fussy, im sure the seats at least are original.....
29th Apr 2012 5:06pm |
