Home > Technical (L322) > Fan orange light always on.......
mjdronfield
I've just noticed that I have a single orange light, always lit, from around the "rotary encoder" on the fan speed control.
Has anyone else had this ?
Wasn't there yesterday.......
(there we go, I've managed to side step any knob jokes.......) Laughing
..and is the indicator for the gear position always lit, behind the gear lever ?
....set me off now.........
Thanks
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #119470 28th Apr 2012 4:08pm
fisha
My gearbox light always glows dimly. Never had the kno... rotary encoder light up like that though.
Maybe pull the fuse on it, or disconnect the battery. Odd one. V8 or else ...
Post #119488 28th Apr 2012 5:47pm
paneldamage
Whats your battery life like? The fan speed indicator fault is a sure sign that the heater fan speed control (resistor pack -aka the hegehog) is faulty. It causes other problems including rapid battery drain. The little red light on the transmission position should extinguish ten mins after the car has been locked. To check, look through the window, dont unlock or open the door.
If it was mine, I would get a diagnostics check done, read the fault codes and go from there. If its the hedgehog, they are about 30-40 quid, get a gen LR item from dealers- I see plenty on the bay but stories about early failures also.
There is plenty on here about the hedgehog.....
Post #119514 28th Apr 2012 11:01pm
mjdronfield
Cheers.
Battery and FSR were replaced in November with genuine units, so I'm not initially expecting those to be an issue.
I shall attempt to find the fuse for the control panel, and see if pulling that resets it.
Failing that, I'll unplug the panel and put it back.
If it's still joggered, I shall have to do a bit more head scratching..........
Thanks
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #119524 29th Apr 2012 8:59am
Ooh. better hope its not the control pack, just had mine replaced, cost warranty 600+ for the part. There is nothing that can't be fixed with a hammer😜😜
Post #119529 29th Apr 2012 10:21am
mjdronfield
Just removed the fuse (F12 Passenger Compartment), and replaced, and the light is still on.
Unit works fine...........just the piggin orange light........
Will remove the unit - and resist temptation to strip it down...........
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #119539 29th Apr 2012 11:23am
Resist..... Expensive part, which works, to spanner apart, for a little orange light. Whistle There is nothing that can't be fixed with a hammer😜😜
Post #119567 29th Apr 2012 4:03pm
T24RES
Is this the 'Triggers Broom' version of the FFRR? Whistle
Certainly getting your pennies worth from that warranty, good on yer Thumbs Up
Post #119571 29th Apr 2012 4:42pm
Nah, im just a bit fussy, im sure the seats at least are original..... Whistle
If its broke, and covered, it will be fixed.....so long as it doest cost me owt. There is nothing that can't be fixed with a hammer😜😜
Post #119577 29th Apr 2012 6:06pm
