![]() | Home > Maintenance & Mods (L322) > De-cat Td6 ? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
Has anyone de-cat'ed their Td6 ?
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
Would it not have to be re-fitted come MOT time? Reformed |
Yes part of the MOT now |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
Hi Mark
Sea Aitch Member Since: 17 Feb 2011 Location: Hertford Posts: 120 ![]() ![]() ![]() |
Mark
Thanks gents,
5IMON Member Since: 27 Nov 2011 Location: London Posts: 165 ![]() |
Is it possible to remove the egr alive on a tdv8? |
There is a bit of info here ;
One thing I forgot to mention was cleaning the inlet manifold. My TD6 smoked like the winner of a smoking contest on national smoking day. When I replaced the EGR I saw what looked like a 5mm build up of carbon in the inlet to the inlet manifold. I took the manifold off and ran it through a cleaner bath, washed it out with petrol and finally hot soapy water. As well as making one hell of a mess I had a spotless manifold which combined with an EGR blanking meant no more smoke.
So is there a howto on a De-Cat for a TD6?
That's all there is to it Joe, I've done it to several diesel vehicles and not noticed any difference. Not worth the effort IMO unless you have a sick Cat |
Mmmmm food for thought, thanks John. .
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
Was talking to a friendly MOT mechanic the other day. The rules are that a diesel car doesn't have to have a Cat fitted, but if one was fitted as original then it needs one for an MOT pass. He did say that most people don't know if one was fitted as standard on any particular vehicle and most mechs probably won't check anyway. |
As 47P2 says not much noticeable difference apart from more noise in the cabin which I like, weird I know.
