Home > Maintenance & Mods (L322) > De-cat Td6 ?
mjdronfield
De-cat Td6 ?
Has anyone de-cat'ed their Td6 ?
I am thinking about it, for no ther reason than I hate all the emission stuff strangling the engine.
I have a K & N and have removed the egr, so thought it might work.
Mines a 2003, so assume I'd not have any dashboard lights or errors thrown up ? Is it EU3 ?
Perhaps I'm just looking for more things to do !!
Cheers
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #118672 22nd Apr 2012 7:50pm
Reformed
Would it not have to be re-fitted come MOT time? Reformed
Post #118685 22nd Apr 2012 8:32pm
Yes part of the MOT now
Post #118698 22nd Apr 2012 9:17pm
No it's not.
The requirement in the mot for a cat is only applicable to spark ignition engines ie petrol, lpg etc.
You don't need a cat for an mot on a diesel engined car even if it had one at manufacture.
The mot test for a diesel is as before, a smoke test only. emissions doesn't come into it.
You can take the cat off if you like but the exhaust smells a bit "fumey" if you do.
Post #118704 22nd Apr 2012 9:36pm
ahebron
New Zealand
Hi Mark
I have had my 2003 TD6 de-catted and I have removed the EGR.
Had a look down the inside of the CAT once removed and could not see much light out the other end so it might have been a bit blocked. Nothing to bring up error codes as no sensors on the exhaust pipe.
Only real downside is it does stink but hey its a diesel and there is nothing else on mine to say its a diesel. The engine is a bit more audible which I like.
Adrian VW Amarok 2014 Highline auto
Post #118728 23rd Apr 2012 9:30am
Sea Aitch
England 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Mark
I've removed the EGR valve, fitted a K&N and replaced the CAT with a decat section of pipe.
I did the EGR first, and it kicked out a lot less smoke on acceleration and seemed to run smoother.
I did the decat next, and it accelerated better, and sounded nicer.
Both of these mods appeared to give a slight improvement to economy.
The last thing I did was to fit a K&N. Together with the other changes, this made the car pleasingly more lively (for a TD6). I like the increase in induction noise from under the bonnet, but it may not be to everyone's taste. Economy is good (approx 25mpg) but these changes have improved the driveability of the car, rather than made it more economical, which is fine by me.
No dashboard errors have come up so all is well. Thumbs Up
Tickover when cold does create a bit of diesel fuming though, but as nicedayforit said, the car won't fail an MOT because the CAT has been removed. I've got the option of refitting mine if I have a change of heart, and want it to smell sweeter, but I'm happy at the moment, as it's not really that noticeable.
Colin
Post #118757 23rd Apr 2012 3:35pm
mjdronfield
Thanks gents,
Looks like it could be a reasonable mod for around the £100 mark.....
My Td5 never had a CAT, so didn't worry about it.
I have got used to the extra induction noise from the K & N, but was a little surprised when I first heard it.
I like my car to be quiet when I'm pottering about, and nice and smooth when pressing on, so you could argue I've got the wrong engine !!
A mate of mine had a 4.4 Vogue with a Khan quad pipe exhaust, and it sounded like a Nascar.......
I do wonder whether all of this is leading to me getting it remapped..........as I seem to be eeking out a little bit more driveability here..........and there.........
Cheers
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #118761 23rd Apr 2012 3:53pm
5IMON
Is it possible to remove the egr alive on a tdv8?
Post #118790 23rd Apr 2012 7:30pm
mjdronfield
There is a bit of info here ;
http://www.fullfatrr.com/forum/topic5479.html?view=next
Not much for the TdV8........... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #118793 23rd Apr 2012 7:47pm
ahebron
New Zealand
One thing I forgot to mention was cleaning the inlet manifold. My TD6 smoked like the winner of a smoking contest on national smoking day. When I replaced the EGR I saw what looked like a 5mm build up of carbon in the inlet to the inlet manifold. I took the manifold off and ran it through a cleaner bath, washed it out with petrol and finally hot soapy water. As well as making one hell of a mess I had a spotless manifold which combined with an EGR blanking meant no more smoke.
Post #118802 23rd Apr 2012 8:52pm
So is there a howto on a De-Cat for a TD6?
Is it simply a case of exhaust off, cat off, replace with suitable "decat" pipe, exhaust back on?
And apart from the "smell" is it worth it? .
Post #136659 18th Aug 2012 2:00pm
That's all there is to it Joe, I've done it to several diesel vehicles and not noticed any difference. Not worth the effort IMO unless you have a sick Cat
Post #136663 18th Aug 2012 2:25pm
Mmmmm food for thought, thanks John. .
Post #136675 18th Aug 2012 3:25pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Was talking to a friendly MOT mechanic the other day. The rules are that a diesel car doesn't have to have a Cat fitted, but if one was fitted as original then it needs one for an MOT pass. He did say that most people don't know if one was fitted as standard on any particular vehicle and most mechs probably won't check anyway. Smile No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #136685 18th Aug 2012 4:57pm
ahebron
New Zealand
As 47P2 says not much noticeable difference apart from more noise in the cabin which I like, weird I know.
But with all the soot mine was pumping out I thought it a good idea. I do not know much about how they work on a diesel but it 'looked' very restricted to me when peering down the inside.
Post #136713 18th Aug 2012 10:02pm
