Home > General > Preview: 0.5M Wading Depth, Pah I say!
dan_uk_1984
Was driving in to town today and one of the roads was severely flooded, everyone was turning round because they were in normal cars... It is a fairly long stretch of flooded, flat road about 1/4 of a mile.
The initial marker said 2.5 feet deep, no problems I thought, I drive this route every day to work and back so I know the road, I know from experience that the RR can easily cope with 2.5 foot of water.
Get to the second marker and it's at 2 3/4, starting to worry now as I can see logs stuck in the hedge and I didn't realise the road dipped down, I assumed the first marker was the depth of water along the whole road!
Get to the third marker, the water is at the 3 foot level. At this point I'm beginning to run through my mind how I cant afford to replace the engine and all the interior! But slow and steady with a nice bow wave in front of the car, the water was level with the top of the bonnet but was a good 1.5 foot lower behind the wave so I'm sure the water wasn't in danger of getting into the air intake.
By the fourth marker we're back to 2.5 feet, massively relieved and carry on like it was no big deal. My passenger was in awe, as well as the people who were at the other end turning round.
Another good day to be a Range Rover owner `)
I drove home a different way! It could have been bad, if I'd had to stop for any reason ie a log in the water, or under the water and I'd lost my bow wave I would have been screwed. I also think that if the water had been much higher the car would have thought about floating at the rear and I could tell it was hard work to push that much water out of the way.
So the manual says 0.5M, yet 0.91M is possible!
Post #11493 23rd Jan 2010 1:40pm
The doc
2008 Range Rover Vogue TDV8 Java Black
Sounds like you had some good fun Thumbs Up '09 Freelander 2 TD4 HSE Auto for the Mrs
Using the works Fiesta 1.6 TDCI Sport Van - CHROME FREE THOUGH
Searching for a nice E63 AMG or S8 V10 to replace my "wonky" TDV8
Post #11494 23rd Jan 2010 2:15pm
jope
Norway 2003 Range Rover HSE Td6 Java Black
awesome, you didn't take any pictures?
Post #11496 23rd Jan 2010 3:08pm
dan_uk_1984
No chance of that! I was far to busy not floating away!
Post #11497 23rd Jan 2010 3:13pm
Awsome ,no othe well apointed livingroom could have done that. My one thought is to check the diff oil some time soon because the breathers arn't that high up. Thumbs Up 2008 MY Supercharged
Post #11498 23rd Jan 2010 3:30pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
ive waded with water over the bonnet , and got a bit twitchey thinking about the air intake fortunatley ive extended all my breathers so that was ok and i carry a piece of rubber matting to go under the bonnet were the heater inlet is and the filter good fun tho Thumbs Up Thumbs Up onto no6 Range Rover
Everyone needs a hobby
Post #11500 23rd Jan 2010 3:51pm
EDWARD757
2007 Range Rover Vogue SE TDV8 Java Black
I thought all land rovers were certified to 700mm wading...
Ed
Post #11525 23rd Jan 2010 10:05pm
dan_uk_1984
Ed
Not sure any of them will go to 700mm, the Defender is 500mm, as is the freeloader and RR sport. The D3 is the only LR with a 600mm wading depth as far as I know...
Post #11527 23rd Jan 2010 10:27pm
EDWARD757
Hi Dan,
Just had a quick kyke at the LR website. RR should do 700mm as should the RRS. D4 can do 600 but 700 with Air suspension. Free lander is 500 as you say. I was surprised the Defender can only do 500 too. I stand corrected though, I just thought it was one of those design start points for LR that a vehicle must be able to do 700mm.
I assume your seals held up, etc. Sounds like your getting your moeys worth out of her. Happy paddling,
Ed
Post #11529 23rd Jan 2010 10:52pm
dan_uk_1984
My manual says 500mm. Maybe the Jag engined varients have a relocated air intake on the RR RRS and Disco?
Door seals were all fine, it felt as sure fotted as the P38 whenever I've waded through rivers in that...
Post #11530 23rd Jan 2010 10:56pm
Soor seals were all fine, it felt as sure fotted as the P38 whenever I've waded through rivers in that...
Have to say I am impressed. I guess its that young bravado in you and your belief in what is after all a superb vehicle that cannot be matched by any other. Well done that man. Bow down
Post #11531 23rd Jan 2010 11:27pm
dan_uk_1984
I wondered when you were guna pop up!
Post #11532 23rd Jan 2010 11:56pm
ENVOY
United Kingdom 2003 Range Rover Vogue Td6 Java Black
Ive done lots of wading in defenders Mr. Green and sometimes paid the price for going in to deep Rolling Eyes but i take my hat off to you for going in deep in the FFRR Bow down more balls than me
Post #11554 24th Jan 2010 12:06pm
The doc
Roger I killed my first disco wading too deep Sad '09 Freelander 2 TD4 HSE Auto for the Mrs
Post #11556 24th Jan 2010 12:11pm
Dan, I saw you wading that flooded road with a bow wave for protection the other day and took a pic:
Look at the vastly reduced depth behind the wave its barely over the side steps...
Go deeper next time and use the right gears!
Rolling with laughter
Post #11728 26th Jan 2010 4:39pm
