Home > Maintenance & Mods (L322) > front suspension bushes failed mot
Andy
Well, yet again the FFRR failed the mot. All 4 front lower arm bushes. I replaced these arms only two years ago and they're shot.
This time, I've bought the bushes on their own.
Looking at it, I think I could remove them from the chassis mounting points and remove them with the aid of a bush extractor. Does anyone know of such a tool and where I could buy/hire one from? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #114358 22nd Mar 2012 10:50am
I think you would need a hydraulic press to get the new ones in
Post #114370 22nd Mar 2012 11:52am
Andy
Wouldn't disagree with that. However, I'm sure its possible with a hand held bush extractor whilst in situ, so to speak.
I've done loads when I used to be on the spanners. Then again, I had access to all that kind of tooling then! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #114384 22nd Mar 2012 1:08pm
Andy
Something like this:
http://www.ebay.co.uk/itm/Mercedes-Benz-Bu...2735wt_922 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #114385 22nd Mar 2012 1:10pm
fisha
Noddy, I've personally found that if the bushes are gone, then so are the ball joints themselves at the other end of the arms. I know you've bought them already, but nay be worth double checking the ball joints. V8 or else ...
Post #114402 22nd Mar 2012 4:09pm
Andy
Ive bought the ball joints as a precautionary measure. I plan on fitting the lot together. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #114404 22nd Mar 2012 4:24pm
noddy, pretty sure theres a 'how to' in the wiki re balljoints.. ... - .- -.
Post #114408 22nd Mar 2012 5:09pm
enumbers
Ireland 2004 Range Rover HSE Td6 Adriatic Blue
As a matter of interest who supplied the replacement arms I would expect to get a lot longer out of the arms unless your doing some heavy duty work with the jeep.
Post #114453 22nd Mar 2012 9:36pm
Here you go Noddy,
http://www.rampandwrench.co.uk/main/
Pop by, do the work there and im sure the tool you need should be as well..
Failing that 2 sockets of the correct size, windy gun, strong nut and bolts and off you go Smile
Take some ice and heat the outside of the retainer and then use the ice on the actual bush to help shrink it down just enough while the retainer stays hot Smile
EDIT: sorry wrong link! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #114459 22nd Mar 2012 10:14pm
Andy
Island 4x4. I got two years out of them. That's just driving on-road commuting, and covering about 8,000 miles.
I did call them. They said there was a 2 year guarantee. I was out by two weeks! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #114494 23rd Mar 2012 10:17am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
That's appalling - I'd do that mileage in 2-3 months - and I wouldn't be expecting to change anything that quickly - even if the roads where you live are worse than the surface of the moon.
Cheeky gits.
Post #114496 23rd Mar 2012 10:28am
That's the problem with a lot of aftermarket parts, they just aren't the same quality as OE
Post #114513 23rd Mar 2012 11:32am
Andy
I'm hoping that these genuine bushes will fit the aftermarket arms now! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #114517 23rd Mar 2012 11:42am
Simes
@47p2 : That's true - but the inverse can be true also. Sometimes the aftermarket guys fix a weakness in an OE part. Obviously not in the case of these particular items.
Post #114519 23rd Mar 2012 11:58am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
That is shocking, I am having my rear bushes (ooh er misses) looked at next week so will keep the OEM parts in mind.
On my old BMW 330ci Sport the OEM plastic bushes themselves were notorious for not lasting as long as the specialist aftermarket ones. As to the arms, not sure if they were different. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #114579 23rd Mar 2012 6:49pm
