Home > Maintenance & Mods (L322) > Viscous fan failure
Page 1 of 4 1234>
Viscous fan failure
Is it possible for a viscous fan to fail into an always on position as it sounds like mine has as the whoosh sound increases with revs and doesn't sound boost related to me???
Help me please!! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #113505 17th Mar 2012 10:05am
Indeed thats exactly how they fail normally... Rarely will they stop working at all, 99 out of 100 times they stick on...
Craig Thumbs Up
Post #113510 17th Mar 2012 10:42am
Where's best to get one as LR just quoted �180 for one!!! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #113512 17th Mar 2012 11:11am
Have you tried Island 4x4?
Craig Thumbs Up
Post #113513 17th Mar 2012 11:12am
Is it the same as a BMW unit as wanted to sort it ASAP as I need to do a 300mile trip early doors on Monday Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #113514 17th Mar 2012 11:26am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Mine occasionally sticks on until I floor it, I think it is a tough job to replace, not in the easiest place to access. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #113515 17th Mar 2012 11:33am
Flooring it hasn't worked Sad
Wonder if you can get a kenlowe type kit for it?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #113516 17th Mar 2012 11:43am
Viscous fans fail due to the pin that actuates the internal slide valve stickes due to corrosion.
You can remedy this by taking the fan off the car and looking at the bi-metal spring on the front centre.
The spring acts as a heat sensor and when it gets hot it lenghtens and coils up.
It's connected to the centre pin which rotates to close the valve so allowing the viscous fan to lock up.
Normally what you do is disconnect the outer end of the spring from the body of the fan and then apply a lot of WD40 to the pin where it passes into the body of the fan and then grip the pin with pliers or grips and start moving the pin back and forth til it frees off.
Never had to do it on a TD6 but done it a number of times to other cars.
Worth a try, cheaper than a new fan Very Happy
To stop it happening in the first place it's worth lubricating the pin every now and again.
Post #113518 17th Mar 2012 12:02pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I've removed mine, it's been off a month or so and did a 1000 mile two day trip to Edinburgh and back no problem.
(Not towing BTW)
Needle stays a rock steady middle of the gauge.
Post #113519 17th Mar 2012 12:04pm
ebajema
My brother in law had an issue with his Rover SD years ago, where the viscous coupling failed more spectacularly, it came of the shaft and hit a hole in the radiator. He didn't realize it and the engine overheated in the south of France. He had the car recovered and we replaced the radiator and coupling and the car was fine (no bent cylinder head !!).
Just check that that is not happening on your car. MY 2010 5.0 SC Galway green and sand interior!!
Post #113520 17th Mar 2012 12:23pm
(Not towing BTW)
Ive often thought about removing mine as it drives me mad (noise) but im unsure weather the electric fan comes in when it gets very hot (like on a disco 2) anyone know?
Craig Thumbs Up
Post #113538 17th Mar 2012 1:28pm
Richcl
Well If I've read RAVE correct, the electric fan does come on if engine gets to hot.
Also, I now get to hear a straight 6 rumble and not a vicous fan when I'm driving, try it, most of the time I don't listen to radio anymore, just listen to the 6 cylinder beat! Very Happy
Post #113539 17th Mar 2012 1:31pm
Can you check the same applies to my SC pwwweese... As thats got to sound better too... Wink
Craig Bow down
Post #113542 17th Mar 2012 1:34pm
Richcl
Don't know if my RAVE covers SC...
The TD6 has a huge viscous fan and an equally sized electric fan, recently due to my main engine thermostat being bypassed my engine was over cooling, it struggled to reach the top of the blue segment on the gauge. This tells me that the TD6 runs very cold, so all this aditional cooling is probably only needed if in the Sahara, in deep sand, towing a trailer!
So I now leave my engine cooling to just the electric fan (which as far as I know, has never come on) and in all conditions, even sat in traffic has not budged above mid point on gauge, and their may even be a MPG improvement.
Post #113544 17th Mar 2012 1:44pm
No worries, may try to look next week...
Craig Thumbs Up
Post #113546 17th Mar 2012 2:02pm
Page 1 of 4 1234>
