Home > Maintenance & Mods (L322) > Viscous fan failure
Page 4 of 4 <1234
True but the gearbox also routes its oil through a cooler does it not?
The amount of space around the engine in the engine bay and the transmisson would surely allow for great airflow over it and i dont thrash it much either so it gets plenty of cool down time Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #123116 22nd May 2012 9:07pm
ahebron
New Zealand
And the intercooler.
SWMBO recently bought a 2003 BMW Mini One.
Amongst other issues the engine cooling fan resistor has failed.While researching this issue I came across information which stated that the temperature gauge is very vague and is driven from the computer so as not to concern the driver Shocked . When I get into the car computer settings I can bring up real temperature (which I verifed by external equipment)and the car is sitting at over 110 degrees C and starting to boil over but the temp gauge is dead centre. The cooling fans do not cut in till over 100 degrees. These cars are built by BMW which also had a large hand in early L322s.
I will attempt to find the information
Adrian VW Amarok 2014 Highline auto
Post #123121 22nd May 2012 9:53pm
SteveMFr
Site Sponsor
Funny that you just post this now, Adrian. I hadn't noticed this thread in the past and after having a read accessing the BMW 'secret service menu' (shhhh... Razz ) to check the exact coolant temp was going to be one of my suggestions.
http://www.bimmernav.com/battery.html
Coolant temp is test #7.
Also, one thing to consider is that over a speed of about 30mph, the fans do nothing but enjoy the ride. So if you are positive you'll never sit in traffic, removing the fan should not be too much of a problem.
That said, there is a reason that the fan is there and the thought of having to jump out in traffic and getting my tie caught in the serpentine belt as I desperately try to reinstall the fan does not tickle my fancy. And God forbid SWMBO get's caught somewhere... Shocked Big Cry
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #123189 23rd May 2012 9:10am
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
Since this hot weather has started mines been making a right noise!! I presume it's the fan as it matches the description others have given, so now just the call to remove it or not?? FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #123358 24th May 2012 12:31am
Well I have no intention of removing the fan. LR must have fitted it for a reason
Post #123372 24th May 2012 8:51am
Mine's staying put too, given the fun I had fitting it back on after changing the thermostat. Rolling Eyes That said, it must be there for a reason...... .
Post #123379 24th May 2012 9:19am
ahebron
New Zealand
So following on from all the previous threads has anyone managed to fit an electric fan to the shroud?
I ask this because I think fitting it to the radiator as most electric fans are is not as efficient as the shroud.
Post #123386 24th May 2012 9:51am
TBH i can only see it being there for very hot climates where the aircon may be off with the windows open to ensure air flows over the engine. For us lot it should be ok unless temps go over 40'C FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #123435 24th May 2012 12:58pm
Bimmernav thing doesnt work on mine Sad
Tried a few times and same result.... Wonder if im just at the cutover and its another thing thats disabled/removed... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #123463 24th May 2012 4:47pm
Deasy
United Kingdom 2002 Range Rover Vogue 4.4 V8 Java Black
Has anyone done this on the 4.4 v8?
i have the viscous fan removed on my 300tdi disco and never have an issue, until last weekend when it was very hot 30ish in wales, steep uphill climbs made the temp rise very quickly, but on road was no issue in the heat
but was wondering if i could remove it on my l322 without to much of an issue, or change it to a leccy one?
Post #124836 3rd Jun 2012 5:15pm
iirc the 4.4's are known to overheat anyway are they not so i wouldnt chance it and i'd get an electic one fitted and take the chance to flush the cooling system as well. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #124850 3rd Jun 2012 7:15pm
RenoHuskerDu
France
Ya got an amen from me. Reno, on assignment in France.
Post #129017 2nd Jul 2012 7:46pm
Ahh just like they fitted things to the car and disabled them??!? Wink FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #129022 2nd Jul 2012 7:53pm
RenoHuskerDu
France
OK, I'll bite. I must be missing out on some knowledge here. To what do you refer??? Question Reno, on assignment in France.
Post #129024 2nd Jul 2012 7:57pm
Page 4 of 4 <1234
