![]() | Home > Maintenance & Mods (L322) > Viscous fan failure |
Is it possible for a viscous fan to fail into an always on position as it sounds like mine has as the whoosh sound increases with revs and doesn't sound boost related to me???
Where's best to get one as LR just quoted £180 for one!!! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Have you tried Island 4x4?
Is it the same as a BMW unit as wanted to sort it ASAP as I need to do a 300mile trip early doors on Monday |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
Mine occasionally sticks on until I floor it, I think it is a tough job to replace, not in the easiest place to access. Tom
Flooring it hasn't worked |
Viscous fans fail due to the pin that actuates the internal slide valve stickes due to corrosion.
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
I've removed mine, it's been off a month or so and did a 1000 mile two day trip to Edinburgh and back no problem.
My brother in law had an issue with his Rover SD years ago, where the viscous coupling failed more spectacularly, it came of the shaft and hit a hole in the radiator. He didn't realize it and the engine overheated in the south of France. He had the car recovered and we replaced the radiator and coupling and the car was fine (no bent cylinder head !!).
Ive often thought about removing mine as it drives me mad (noise) but im unsure weather the electric fan comes in when it gets very hot (like on a disco 2) anyone know? Craig ![]() |
Well If I've read RAVE correct, the electric fan does come on if engine gets to hot.
Can you check the same applies to my SC pwwweese... As thats got to sound better too... |
Don't know if my RAVE covers SC...
No worries, may try to look next week...
