Home > Technical (L322) > Headlamp wiper stuck at 45 degrees |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2938 |
Thanks for that. Will try it tomorrow 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
4th Jan 2010 12:10am |
Well, I tried pulling the fuse and re-fitting it, but it's made no difference. I even switched on the ignition just in case, but to no avail. Looks like the motor is u/s 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
4th Jan 2010 2:11pm |
Stebo Member Since: 14 Sep 2009 Location: Northern Ireland Posts: 39 |
BTW I've just read that you should really leave the fuse out for a while, just trying that now. Going to give it ten minutes and stick the fuse back in.
4th Jan 2010 5:04pm |
Tried it tonight using this method and it's worked! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
5th Jan 2010 5:55pm |
jonny142 Member Since: 29 Oct 2008 Location: Sheffield Posts: 28 |
Had the same problem over the last week.... took fuse 28 out...left for 30 minutes then put back...Worked a treat.. Thanks Guys 4.4 V8 Vogue Adriatic - Cream leather |
15th Jan 2010 7:02pm |
Strange how this works- you'd think with no power going to it, it wouldn't move! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
17th Jan 2010 1:51pm |
This problem keeps occuring to my car It's easy enough fixed but getting annoying. Also the left hand fog light is playing up, but all I have to do to fix that is take out the bulb and put it back in again. Getting quite annoying, Anybody and idea if there could be any likley electrical gremlins that would cause problems to the front left of my car! |
26th Jan 2010 10:49am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6406 |
A bit of necromancing but stebo's fix worked for me today. Washers still not delivering but wipers came back to life!
. Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
23rd Jun 2017 6:05pm |
peters Member Since: 20 Feb 2012 Location: amsterdam Posts: 2 |
its number 28 |
25th Jun 2017 8:10am |
It most certainly is
25th Jun 2017 11:22am |
