Home > Technical (L322) > Headlamp wiper stuck at 45 degrees
Andy
Thanks for that. Will try it tomorrow Thumbs Up Thumbs Up 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #10422 3rd Jan 2010 11:10pm
Andy
Well, I tried pulling the fuse and re-fitting it, but it's made no difference. I even switched on the ignition just in case, but to no avail. Looks like the motor is u/s Sad 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #10433 4th Jan 2010 1:11pm
Stebo
2003 Range Rover Vogue 4.4 V8 Giverny Green
I've the same problem at the minute. Wiper stuck vertically instead of horizontally. Mad It happened over Christmas when the weather was -7 so I kina thought it had froze and maybe burnt out the motor or snapped some sort of cable.
If anybody has any other sugestions I'd appreciate hearing them (tried the fuse idea - no luck Sad )
Post #10438 4th Jan 2010 3:32pm
Stebo
BTW I've just read that you should really leave the fuse out for a while, just trying that now. Going to give it ten minutes and stick the fuse back in.
Update .....
When I put the fuse back in after ten minutes not much happened. I think the wiper may have did one sweep (before it never moved) as the arc of the wiper on the light seemed to have been wiped (car not too dirty so hard to tell). Anyway that didn't solve the problem so I futtered about again trying different combinations of lights/ignition on/off, etc. and eventually heard a noise from the front of the car and hey presto, it was sorted.
I think what worked was lights and ignition on, fuse out, squirt washers 6 time (think headlights are every 5 or something) then fuse back in.
Worked for me, thanks for that post with the link regarding the fuse btw!
Post #10441 4th Jan 2010 4:04pm
Andy
Tried it tonight using this method and it's worked! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #10486 5th Jan 2010 4:55pm
jonny142
United Kingdom 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
Had the same problem over the last week.... took fuse 28 out...left for 30 minutes then put back...Worked a treat..
Thanks Guys 4.4 V8 Vogue Adriatic - Cream leather
Post #11121 15th Jan 2010 6:02pm
Andy
Strange how this works- you'd think with no power going to it, it wouldn't move! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #11182 17th Jan 2010 12:51pm
Stebo
This problem keeps occuring to my car Evil or Very Mad It's easy enough fixed but getting annoying. Also the left hand fog light is playing up, but all I have to do to fix that is take out the bulb and put it back in again. Getting quite annoying, Anybody and idea if there could be any likley electrical gremlins that would cause problems to the front left of my car!
Post #11669 26th Jan 2010 9:49am
A bit of necromancing but stebo's fix worked for me today. Washers still not delivering but wipers came back to life!
Post #442454 23rd Jun 2017 5:05pm
peters
Netherlands 2007 Range Rover Vogue TDV8 Stornoway Grey
its number 28
Post #442629 25th Jun 2017 7:10am
It most certainly is
Front fusebox (glove compartment) Fuse 28, third from the right, top row, 30amp Thumbs Up .
Post #442651 25th Jun 2017 10:22am
