![]() | Home > Maintenance & Mods (L322) > Help; rear brake binding |
vanquishspirit Member Since: 10 Feb 2012 Location: United Kingdom Posts: 131 ![]() ![]() |
I have been achieving 9mpg around home with the brake problem, but I reckon it was sticking on slightly before which is why it kept wearing the discs out, well to be accurate the offside disc which doesnt have a warning wire in the pads. Cheap! Anyway, before the 9mps it usually 14.5. Yuk, but I reckoned the depreciation of switching a 2006 to a 2012 TDV8 with an all new FFRR out next year would be way more than the fuel bill |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1521 ![]() ![]() |
As Craig said, I ended up getting both done albeit one after the other.
swirl80 Member Since: 11 Dec 2011 Location: Northumberland Posts: 46 ![]() ![]() ![]() |
I've had my 2007 FFRR for 3months now and started to hear a grinding noise, bit of investigation work i found it was the rear drivers side pad had completely worn to the metal and subsequently discovered it was cos of a sticking caliper. So having the disks (cos 1 is ruined), pads and calipers replaced by a neighbour as I don't want to drive it but my question is, should i complain to the $tealers about this?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35490 ![]() ![]() |
the binding brake could have started the next day after you brought the range so i dont think you have a case with the dealer especially after 3 months.... ... - .- -.
thought that'd be the case |
As Stan states above, the brake caliper can stick on at any point unfortunately leading to ruined pads & discs... They can last a couple of hundred to a couple of thousand miles depending on how much the brake is stuck on! The more stuck the quicker it wears, i am surprised most drivers state the car drove the same.
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 ![]() ![]() ![]() |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3759 ![]() ![]() |
That's normal for a supercharged. It's good to get into double figures booting a |
Mrbadger Member Since: 06 Jan 2013 Location: Essex, uk Posts: 19 ![]() ![]() ![]() |
My ajv8 is at 16 and smells a bit, makes me wonder if I have the same issue too |
Any tips for freeing up the suck calliper to see if it temporarily cures it? |
you could try , wheel off, pads out, clean the pistons and ease them in slightly .. ... - .- -.
The cost of JLR replacements are low now Gary. Not worth the strip down to free off then the same labour to do the job again for an extra £75ish for a JLR re-manufactured unit from Dan... |
mmm hands (very) dirty....
Will buy a couple of units from Dan.
