![]() | Home > Maintenance & Mods (L322) > Help; rear brake binding |
Update,
Its not the Calliper Binding its the Disc that has worn so much the pad is grinding against the rusty edges!!!
Its a manual Handbrake how do I check if its binding? |
Also the Rusty Edge is MUCH wider on this disc than the other three. On the other three there is only a very thin inner lip with the disc seemingly extending right to this thin lip? On the dodgy one the lip is wide and the pad is over it? |
