![]() | Home > Maintenance & Mods (L322) > new battery ...95ah or 110ah |
arron Member Since: 22 Sep 2010 Location: lincolnshire Posts: 123 ![]() ![]() ![]() |
get some one to hold the bonnet while you take either the top or bottom end of both rams off, once the rams are disconnected lift the bonnet to the vertical position. on the hinges you will see a pivot latch which need turning and lifting over the saftey niple to hold the bonnet in place. simples |
trafpol Member Since: 15 Jun 2011 Location: Surrey Posts: 141 ![]() ![]() ![]() |
I fitted the Varta 110ah/920cca on Saturday. Engine turns over nice and bags of power.
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 279 ![]() ![]() |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
Scarey where did you buy your battery from to get the 'no quibble' exchange? Am struggling loads with battery2u about my Varta I!, only 16 months old ![]() Am seriously considering buying a new one from a local place so any issues I cna simply take it back and plonk it on their counter.... Cheapest local to me is ECP �133 for the Bosch Silver S5 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35647 ![]() ![]() |
got mine from eurocarparts ...t24res reckons they are giving a discount [15%?] at the moment....
They weren't on Monday when I got mine - but I thought �133 was a pretty good price anyway |
''battery15'' discount code ....that is what it says on their web site.
Cheers mate, just ordered one with the 15% discount so got it for �113 including delivery, from ECP When I put the new battery on, and change the FSR (bought one to replace just in case it is that causing the drain), whats the first things I should be checking to find this god damn drain? Thanks again everyone |
first thing to do when the battery is fitted , is to turn the steering wheel full lock left and then full lock right, this sets the steering parameters ..
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Well, 2 years on from fitting the new Varta, and with the colder starts, I get the bastard HDC Inactive greeting each morning. Not starting problems yet, but I guess regular use helps with this. Was hoping for more life than this, maybe a warm cosy garage, and electric blanket or a trickle charge unit is the answer? .
Is it possible to fit a vag style blanket around it and under it at all?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
OK. Got the Bosch S5 from Europarts with the 25% discount and next day delivery. Whilst I was waiting got the Bonnet in access mode. Dead easy thanks to tips about getting the clips off the snap on studs at the bottom of the gas struts. Push them down to get them off and up the grooves to put them back on.
